Results 1 to 10 of 13
Thread: carbon canister
    Default carbon canister
    hey guys/gals,
    has anyone removed the carbon canister completely out of a 4age ???
    what will happen to the engine if you do ???
    i know its part of the emmisions but that doesnt matter
    any info will be great
    thanks
    Colin
    Ferny Grove
    just move it, don't REmove it
    i put mine in behind the front bar on that overhanging section of steel the horn is attached to.
    i'll grab a pic later if i can.
    Akio
    Mt Haruna
    Japan
    you can use a smaller or other manufacturers canister too. if space is at a premium something like charade or S13 canister will work.
    as gilly said just move it dont REmove it...
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    wont fuel fumes leak? not sure though!
    Jonathan
    You will not notice having it or not in terms of how the motor runs and power. Most modifyed cars don't have it hooked up properly anyway.
    Fuel fumes travel this path:
    fuel tank> alloy tube to engine bay> charcole canister> vacuum hose> valve (sometimes electric)> vacuum hose> throttle body> combustion chamber.
    The valve is ment to open at part throttle. On a 20valve this is electric operated by the ECU.
    Ayden
    Silverwater
    yeah i had a look at mine and there there one of the hose from underneath to nowhere so hasnt really effected anything but it was like that when it was imported
    Jonathan
    The big hose under the canister is a drain/overflow or whatever. It is not ment to go anywhere. It will go to either the chassis rail or the road.
    Ayden
    Silverwater
    oh right fair enough seemed odd just hanging there though. sorry to go off topic but mine was making an odd hissing type of noise when it when sitting there after cooling down any reason to that? or is it just the noise of it going through?
    性交を愛する
    Yank the fucker out.
    Jonathan
    Hissing noise can happen at any time, even with the motor turned off. Often when the car is just sitting in the sun. Vapour from the tank being released.
  1. Wtb carbon carbon carbon
    By zacha86 in forum Cars or Parts Wanted
    Last Post: 10th December 2012, 05:58 PM
  2. Charcoal canister
    By Low Style in forum Technical - Questions
    Last Post: 19th October 2010, 02:36 PM
  3. carbon canister
    By 86adz in forum Technical - Questions
    Last Post: 1st August 2008, 09:54 AM
  4. charcoal canister
    By Hyuga in forum Technical - Questions
    Last Post: 14th October 2005, 07:13 PM
