Page 1 of 12 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 111
Thread: Pauls 4AGTE Sprinter
    Paul
    Default Pauls 4AGTE Sprinter
    Well I thought that it would be about time that I started a build thread on these forums. The basic run down is that I bought the car as a rolling shell, it came with a box of bits including a 4AGZE which I have since found out is buggered. What has happened so far on the build.
    Repray in Mazda Skyish Blue
    14 x 6 Mesh rims
    Coil overs in the front with KYB's and 6kg springs
    4.5kg in the rear with KYB
    Currently running Corona discs but have RX-7 calipers that will go on once I get some 15's
    4AGZE fitted with a Kelway high mount manifold and T25 turbo
    Running an Adaptronic Computer
    PWR intercooler
    3" mandrel bent exhaust (probably too big)
    Excel radiator
    twin 12" themo's
    Upgraded Starion Brake master
    T50 box with Exedy HD clutch
    T3 adjustable strut tops
    Cusco Strup brace
    Yet to do:
    Rebuild the engine
    Get it tuned so that I can get some track time then probably upgrade the front brakes, and diff.
    I hope that you enjoy the photos as there is going to be alot of them.
    Paul
    Paul
    I think that I have got these in order
ID:	833   Click image for larger version.
ID:	834   Click image for larger version.
ID:	835   Click image for larger version.
ID:	836   Click image for larger version.
ID:	838   Click image for larger version.
ID:	839   Click image for larger version.
ID:	840   Click image for larger version.
ID:	841   Click image for larger version.
    Paul
    Some more photos of the build
ID:	843   Click image for larger version.
ID:	844   Click image for larger version.
ID:	845   Click image for larger version.
    Paul
    more again
ID:	847   Click image for larger version.
ID:	848   Click image for larger version.
    Paul
    still more
ID:	850   Click image for larger version.
ID:	851   Click image for larger version.
ID:	852   Click image for larger version.
ID:	853   Click image for larger version.
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    Sweet as man, done anything else to it since I was round last?
    Paul
    Nope, I only got back from south america on Wed... I am probably going to pull the engine this weekend to give it a freshen up, rings and bearings and to try and find out why there is water in the oil. No luck with the ADR on the seat either. They only had test data for the Sprint and a couple of others so let me know what you want to do about it all.
    Paul
    Justin
    DC
    Downtown
    USA
    I'll see what I can sort out and I'll PM/Call you in a week or so.
    J
    Paul
    Turns out the engine might be ok. Thought that I would just flush the engine with some old oil that I had from my other cars. It is still black which is a good sign, I am just going to do some more work to sort out the cooling system and then it should be right to go for a tune. Should be good.
    Paul
    Veteran Wally's Avatar
    fuck yeah! looks awesome mate!
    4AGE 16V
  1. 86 life-4agte sprinter
    By john84ie in forum AE86 Owners Forums
    Last Post: 21st February 2012, 08:19 PM
  2. 1985 aus delivered sprinter ae86-4agte
    By koulouris#03 in forum Cars for Sale (Toyota Only)
    Last Post: 21st July 2010, 05:48 PM
  3. E.O.I 4agte sprinter
    Last Post: 5th July 2009, 03:44 PM
  4. My 4agte Sprinter.
    By Tim in forum AE86 Owners Forums
    Last Post: 16th May 2008, 09:11 PM
  5. 4agte SPRINTER OR KE70 Conversion package
    By tipper86 in forum Car Parts For Sale
    Last Post: 12th November 2007, 07:36 PM
