If your fuel pressure drops with revs then you have a problem. Could be blocked filter/pickup, dying pump or too small/crimped lines (actually scratch that last one, you're measuring BEFORE the lines).
Also just check that your FPR is getting a manifold pressure signal (runs through a VSV stock, you can run it straight from manifold as a test though to see if anything changes).
