Results 1 to 10 of 11
Thread: Harder spring rates, ride height and compressed rates.
    Veteran Breaka's Avatar
    Matthew
    Pottsville
    Default Harder spring rates, ride height and compressed rates.
    I'm after a little help here.
    Basically I'm after harder rear springs but wanting to keep the existing ride height.
    Is there an easy way to find out what free height measurements I need to give the spring manufacturer when wanting a harder spring (than ones in atm) whilst maintaining the same ride height?
    Any help much appreciated.
    Matt.
    Matthew
    Pottsville
    Rates I'm unsure of and free height is yet to be measured.
    Basically I made this thread to find out what I needed before I sent you an order
    Veteran blair's Avatar
    Blair
    Sheldon
    Post up some pics of current height man
  • #4
    Matthew
    Pottsville
    Yeah, shouldn't have gone into this half arse and asked questions once I new current heights and what not.
    Would get pics right now but I just had to drop the car off to the mechanics because the clutch isn't working (Hydraulics I'm pretty certain). Driving clutchless through traffic and intersections aint that fun!
  • #5
    Veteran shift_rook's Avatar
    SE Burbs
    should have fixed the problem yourself with the help of the dc crew haha, easy enough
  • #6
    Matthew
    Pottsville
    Quote Originally Posted by shift_rook View Post
    Yeah, should have. But I'm juggling three cars at the moment and I want the car fixed ASAP. Can't wait til I no longer have to pay some dude to fix my shit!
  • #7
    Rob
    Moorabbin
    Hey if you want a formula you can use this:
    L2 = L1 - m(1/k1 - 1/k2)
    Where:
    L2 = new spring open length (mm)
    L1 = original spring open length (mm)
    m = weight applied to the spring (kg) basically vehicle corner weight.
    k1 = original spring rate (kg/mm)
    k2 = new spring rate (kg/mm)
  • #8
    Matthew
    Pottsville
    Quote Originally Posted by RobertoX View Post
    Where:
    Awesome, thanks dude!
  • #9
    Rob
    Moorabbin
    No worries,
    keep in mind though that it was worked out empirically based on a linear perfect spring.
    So it'll give you an approximate only. It'll be a good starting point.
    I take it you'll be getting some custom springs wound? Chat to the spring maker and see what they say before they make them. If what they say is very different then follow them up about it.
    Don't specify an open length to them, just say you want standard height. That way if they mess it up then they have to fix it
  • #10
    Todd
    Auckland
    Auckland
    New Zealand
    i always just measure compressed height of spring, then goto spring manufacturer and say this spring compresses to this height in my car and i want a new one that will compress to the same height but in XXX rate, that way if its slighly off you can go back and get it adjusted to suit
  • Page 1 of 2 1 2 LastLast
    1. Spring rates?
      By lappy in forum Technical - Questions
      Last Post: 31st July 2011, 03:08 PM
    2. Spring Rates
      By riojin in forum Technical - Questions
      Last Post: 11th November 2007, 02:48 PM
    3. Spring Rates
      By Dan_AE86 in forum Technical - Questions
      Last Post: 12th October 2007, 04:24 PM
    4. Spring rates
      By thekid in forum Technical - Questions
      Last Post: 17th November 2005, 02:16 AM
    5. spring rates
      Last Post: 12th September 2005, 09:02 PM
