Results 1 to 3 of 3
Thread: Standard 4age fuel pump limit?
    Tom
    SOR
    Default Standard 4age fuel pump limit?
    I just got myself a smaller pulley for my ze to increase boost. Problem is I'm only running a standard 4age fuel pump in my car just wondering if the pump will be able to supply enough fuel to the engine.
    Thanks
    Jonathan
    My feeling is the pump will be ok, but I don't know.
    If you want to run a fuel hose into a bucket, and turn the pump on, you can measure the time it takes to fill 1 litre. Then use a online calculator to see how much power your fule flow rate is good for. Use this as a rough guide, or get a pump bigger than you need.
    john
    nsw
    liverpool
    if your worried find someone wreacking a s13 or skyline ... get the fuel pump and it will flow more then enough for what you need or better yet get a brand newie.
  • Similar Threads
    1. 4AC fuel pump - replace mechanical pump or put in eleectic pump?
      By Sprinterman in forum Cars or Parts Wanted
      Last Post: 19th March 2012, 07:57 AM
    2. Replies: 2
      Last Post: 5th April 2010, 06:54 PM
    3. Standard 4age Fuel Pressure Reg
      By Daim in forum Technical - Questions
      Last Post: 6th March 2008, 08:26 AM
    4. 4age fuel pump
      By 4age '71 in forum Technical - Questions
      Last Post: 7th December 2007, 12:39 AM
    5. 4age fuel pump works with one ecu... not with another
      By devolutio in forum Technical - Questions
      Last Post: 4th October 2006, 07:39 PM
