I just got myself a smaller pulley for my ze to increase boost. Problem is I'm only running a standard 4age fuel pump in my car just wondering if the pump will be able to supply enough fuel to the engine.
Thanks
Thanks
My feeling is the pump will be ok, but I don't know.
If you want to run a fuel hose into a bucket, and turn the pump on, you can measure the time it takes to fill 1 litre. Then use a online calculator to see how much power your fule flow rate is good for. Use this as a rough guide, or get a pump bigger than you need.
if your worried find someone wreacking a s13 or skyline ... get the fuel pump and it will flow more then enough for what you need or better yet get a brand newie.
