Results 1 to 10 of 10
Thread: 4A Distributors
    Senior Member Stain's Avatar
    Derek
    Far North
    Default 4A Distributors
    Can you use a dissy from any 4A engine on another 4A engine?
    Reason I ask is I've just rebuilt a AE92 Smallport 4AGE, although I don't have a dissy for it...
    But I do have a 4AC and AE82 Bigport 4AGE dissy here... will they work?
    Thanks
    Dave
    Quote Originally Posted by Stain View Post
    Thanks
    unfortunatley no they wont
    a 4ac dizzy is very simple with points and works independantly
    a 4age bigport dizzy is electronic but works in a basic way to give the ecu a signal of engine speed and what not.
    a 4age smallport dizzy is from my understanding very close to gze Crank angle sensor, with the distributer part built around it.
    reason i know this is that when using an aftermarket ecu they reckon (especially for megasquirt) that a smallport dizzy gives out a nicer signal than the bigport one.
    i believe small port dizzy has 4 wires as opposed to the big port dizzy having 3 wires.
    Derek
    Far North
    What if I'm planning on using a stock Bigport ECU? Wouldn't it be better to use the Bigport dissy? or is the mounting phyiscally different?
    Veteran slydar's Avatar
    Dimitri
    all 16v 4age dizzys will physically fit.
    but only dizzys from an ae82 twinky, or a jdm 86 will work.
    big mr2 wont work. neither will small port. different cas/cas signal.
    im not sure about early ae92.. i.e the big port with the 42 crank.
    Dimitri
    and so.. you have the right dizzy to go with the ecu, and yes itll fit in the small port head NP.
    Derek
    Far North
    Okay cool, that's all I needed to know.
    Trev
    Queensland
    Redbank Plains
    Quote Originally Posted by ke70dave View Post
    Just thought that I would add that the AE80 3ac & AE82 4ac dizzy is electronic.
    Vancouver, BC
    Downtown
    Canada
    go have a look at the tech doc on www.autoshop101.com I can't remember which one 96 maybe? It gives an expanation of ESA (generally bigport) and VAST (generally smallport) ignition systems.
    Ke70dave - do you have much experience with megasquirts? I'm having a little bit of difficulty getting it to recognise the signal from my bigport dissy. I've modified the NE signal wheel (24 tooth) to a 12-1 decoder wheel, but no loving so far! I'm refitting the standard wiring and ecu to get it running and will play with the MS2 on the side.
    stefan
    vic
    eastern suburbs
    Quote Originally Posted by Chrisso View Post
    serious question! does anybody in australia have any idea about megasquirts? i know they the one of the most bang for buck aftermarket ecu's but it seems that no one in australia has any clue about them
    Vancouver, BC
    Downtown
    Canada
    have a look at www.msefi.com (megasquirt forums). There are a number of guys on there and I've come across a few from toymods.
  1. 4age 16 distributors interchangable?
    By ibby86 in forum Technical - Questions
    Last Post: 15th November 2012, 01:04 PM
  2. 2TG distributors
    By Andy San in forum Technical - Questions
    Last Post: 1st June 2010, 11:17 AM
  3. 4AGE DISTRIBUTORS
    By GZE KE70 in forum Cars or Parts Wanted
    Last Post: 28th January 2008, 06:20 PM
  4. Bigport distributors
    By Gilly in forum Technical - Questions
    Last Post: 29th January 2006, 11:11 AM
