you need to power up the big chunky orange wire in the loom. this runs the injectors and a few other things. it will be around where the battery is.
the ecu only switches grounds to the devices. and the big chunky wire supplys positive power to the devices. it is usually switched by the "efi main" relay. i just put a new relay in near the battery.
have a look here
the first box of wires is what you need to connect to make it work.
