Results 1 to 10 of 43
Thread: Sr Powered Rolla
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    Default Sr Powered Rolla (looking at selling)
    Hey, this is my car, the pics are pretty self explanitary
    When it was first running
    Specs
    Chassis: KE70 Sedan
    Mods:
    Enlarged Tunnel
    G/Box hole 80mm back to accomidate nissan box
    firewall behind back seats as per engineers instruction
    corolla engine mounts cut of cross member and welded back on to suit SR20
    RX7 series 2 rubber engine mounts
    Engine & Driveline:
    N/A SR20 out of S14 silvia (VVT model, purchased from just jap)
    S13 silvia turbo G/Box
    ST165 Radiator
    Custom catch can
    tailshaft made to suit by Hardie Spicer in Moorebank
    2.5' exhaust to cat made by me and dad
    2' cat back exhaust by penrith city exhausts
    Suspension:
    XT130 Corona front struts & hubs
    struts shortened to suit SV21 Camry inserts
    Noltec bushes throughout
    Noltec weld on hieght adjusters in front
    S13 silvia coilovers in rear
    AE86 sway bars front & rear
    Noltec adjustable panard bar
    350lb King Springs front
    200lb king springs rear
    Noltec Camber adjusters
    Brakes:
    4 spot hilux 4WD calipers front
    Corolla booster modified to suit toyota 4 stud master
    MA61 supra master cylinder (15/16)
    Peugeot 604 Front rotors
    RA60 celica rear drums
    Fuel System:
    Custom 5/16 steel fuel lines under car
    twin VL pumps
    VL in tank Pump
    Custom surge tank
    Mitsibishi unleaded filler neck
    Interior/exterior:
    corona internally adjustable mirrors
    tacho dash with VDO electronic speedo
    8 ball gear knob
    Modified RA60 celica seats
    Wheels:
    15x7 0 konig rewinds with 205/50/15 AO48 yoko semi's
    Coming Mods:
    rear disks
    re-do rear suspension (= length 4 link)
    re-do tunnel (make it neater)
    boot mounted battery
    oil cooler
    remote oil filter
    a few body braces
    Quad throttle bodies
    extractors
    new cams
    adjustable cam gears
    SR20 turbo injectors
    Retrim (black leather)
    Roll cage (maybe)
    So far all the work has been done by my Dad and Myself, exluding the tailshaft, exhaust & wiring so if anyone has any questions I should be able to answer them
    Wiring:
    Sideshow's Perfomance Wiring, Ask For Jim 0415 904 947
    Tailshaft:
    Hardie Spicer, (02) 9600 6333
    beau
    Bathurst
    Put in the strut towers yesterday & today for the rear coilovers, it was raining today so I couldn't weld , so I just shaped everything for welding tomorrow
    This is under the rear inner gaurd
    this is in the boot
    the other grey tube thing in the background is where my old spring setup used to run, made to much noise and frankly, was pretty crap hence coilovers. sould have them in properly tomorrow, post up pics then of that and of the whole car with new wheels and bumpers tomorrow night
    beau
    Bathurst
    Got the coilovers in today, just gotta clean it all up tomorow and all will b good
    in the boot
    inner gaurd
    this is my new rear bumper, pain in the ass to make fit (please excuse general crudness of photos)
  • #4
    beau
    Bathurst
    I know that it costs money to build a good SR, but i built this car to eventually demoralise most street registered cars and ultimately, thats what i plan to do...
    and after talking to a few engine builders (pa's mates) that have been building performance motors for more years than I've been on this planet, i can safely say that most people spend way to much money on brand names instead of well researched products and info.
    for example:
    if im building an SR to make 200-250rwkw, why do i need HKS, Tomei, Jun etc components, when there are several australian companies that make cams, rods, pistons etc that are used in several forms of motorsport and have proven to be plenty tough for what i want to do.
    Not only that, but they're half the price.
    im not building a drag motor so I dont need massive internals, i want a motor that leans more towards torque and drivability, not outright power, similar to a rally motor (higher compression, less boost)
    me and my dad will most likely be rebuilding it ourselves because in the past we have found that the best way 2 do something is to take the time to do it yourself, not pay someone mega dollars 2 do a half assed job
    P.S. I know that several people will probably disagree with me on this but this is my opinion and i am only posting it up to help guide others if they wish to follow my path, so if you dont agree, please dont bombard this post with abuse
  • #5
    beau
    Bathurst
    no, to much stuffin around to bother with a mechanical speedo, i just put a VDO electronic speedo in the KE70 dash cluster, saved a heap of stuffin around with ratio boxes etc, and i can just reset it if i get different wheels, diff ratios etc
    sorry i didnt reply earlier, as I'm pretty sure you guessed i havent been here in a while
    ::UPDATES::
    its black now, has konig rewinds that fit properly, has hit a roo (stupid wildlife ) been fixed and generally thrashed and abused, got a jdm headlight setup coming in the next few days, a jdm lip if somebody reads there pm's, I'm trying desperately to get some tein coilover to do what i want and I'm plannig to do a few more suspension mods, mainly just pull my finger out and get stuff done.
    and this is what i want to do next (kinda)
    i want do do the front struts a little differently, put equal length four link bars in it, and a watts linkage setup but this is the general plan
  • #6
    beau
    Bathurst
    the red links with the holes are swaybar arms, the holes are for adjustability near the ends and probably to have less weight or to provide more flex in the rest of the arms, this idea is kinda half way between standard adjustable sway bars and full blade type adjustable sway bars as found on V8 supercars and such. The blade system is great for adjustability but to easy to break so this is a good second. The under car pics of the white car is of the john smith bathurst trd race car
  • #7
    beau
    Bathurst
    got my quad head lights wont be goin in till i get my phat JDM front lip (yo ) from gilly, should look quite the goods with a new lip, quads and flat black with a yokohama sticker across said lip
    some of you may have notice that the only wank factor sticker on the car is said yoki sticker, well if the older of you will remember back to a bad 80's movie called canonball fever with john candy in it. There's a red lamborgini countach that skips across a pond like a stone and the dude driving it has a spare rear wing on his lap at the time, well that car has a tyre sticker across the front lip, thats my inspiration incredibley lame i know, but thats my story and I'm stickin 2 it
    Right, i finally decided to get off my arse with this thing, 2 trips on bad country rds has made the decision for me. The front lip and quad light are gonna have to wait for a while, hopefully I'm ordering some new koni sports mr2 inserts in the next few weeks and then I'm gonna be making up some new coilovers front and rear with some new springs to get rid of the shitty kings progressives that ive got at the moment. If time permits, I'm going to setup an equal length four link setup in the rear also.
    Watch this space, I'm going to do a proper write up on the struts and four link setup.
    Quady quad quad quads
    Last edited by sr_rolla; 19th December 2008 at 11:47 PM. Reason: i felt it was nessecary
  • #8
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    get some pics up yo!
  • #9
    beau
    Bathurst
    the rollaclub warragamba cruise/photoshoot from a few weeks ago.
    Last edited by sr_rolla; 19th December 2008 at 11:59 PM. Reason: i wanna, long live editing
  • #10
    beau
    Bathurst
    also warragamba cruise
    Last edited by sr_rolla; 19th December 2008 at 11:58 PM. Reason: destroying evidence
  • Page 1 of 5 1 2 3 4 5 LastLast
    1. SR Powered Sprinter
      By hansen in forum AE86 Owners Forums
      Last Post: 14th February 2013, 01:22 AM
    2. Georgetop powered ke70
      By Jacobxxx in forum KE70 / AE71 Owners Forums
      Last Post: 19th October 2012, 09:40 PM
    3. FS: AE86 Shell Bargain, SR/RB hybrid box, Sr Box no Bellhousing
      By DR86FT in forum Cars for Sale (Toyota Only)
      Last Post: 21st May 2009, 11:05 AM
    4. SR Powered Rolla
      By slydar in forum KE70 / AE71 Owners Forums
      Last Post: 25th June 2008, 04:30 AM
