new pics end pg2
needs lock spacer
xt130 LCAs going in tomorro
chop the rears for time being
and new oil & filter
stil waitin on SSR XR4s
then will get an alignment
new pics end pg2
chucked in new filter and oil
picked up some xt130 LCA with new bushings and steering arms. now i have a spare pair if i bend the 86 pair
pulled everything out and gave the wheel arch a quick touch up job with some black paint. came out looking heaps better
quick squirt of paint
2morro i will do the other side and chop the rears for time being.
nice man! impressed on tha build~
keep it up
thanks boys
xt130 LCAs are in. but toe is soooo fuked up dont even kno if ill be able to get it to an aligner.
can i jus wind out the tie rods by eye to get it as even as possible...? will that work?? is it because 86 p/s arms shorter than stock ke ones?? any help appreciated cheers
apart from that looking good more updates soon
looks good
yeah wind it so it looks sorta straght to drive it then get the alighner to do the rest
thanks mate
could get the measuring tape out and try it that way?
im guessing if you get the measurement from the fron of the wheels to the back of the wheels it should work pretty good...
just a suggestion, never tried it before but i think it should work... if you can get clear measurements...
good luck
