Results 1 to 10 of 13
Thread: 4age knock sensor different?
    Default 4age knock sensor different?
    are the 4age bigport and 4age smallport knock sensors differant?
    so if i run a bigport sensor on a smallport would i have troubles?
    There is no bigport 4age knock sensor. they only started it on the smallport and from then on.
    so if i had a smallport loom and this was not pluged into the bigport motor i would have problems?
    can you tell me what colour the wire is going to the smallport knock sensor?
    i have 2 in my loom on that side that have no plugs
    I believe this may be one of my probs
    Trev
    Queensland
    Redbank Plains
    Quote Originally Posted by Matt-AE86 View Post
    Correct, bigport 4agze has a knock sensor thoough.
    Quote Originally Posted by Trev084 View Post
    from then on.
    10characters
    well that exsplains it as i had a gze block running na. so thats why i may have a problem.
    so you dont know what colour the wire is?
    [QUOTE=wide s13;14141]so if i had a smallport loom and this was not pluged into the bigport motor i would have problems?
    EDIT: Saw user has GZE motor.
    What do you intend to do ? Continue running the GZE N/a or Supercharger/Turbo Charge it. I guess it would be a waste to convert to bigport loom etc.
    Knock sensor wire is Black. It should have a Grey insulation around it, don't get it confused with the O2 sensor wire though. You should look for pinouts.
    my original motor was gze with hi-comp ae111 pistons.
    blew it up.
    then got std bigport 4age had problems that im having with my 7age
    so looking for things i may have missed.
    i have not got the 7age knock sensor pluged in so im guessing it could be all related.
    Timmy D
    North
    Default knock sensor
    I can only talk about ze senors im not sure about na
    But i had a big port (gze) motor running a small port ecu without a knock sensor and at 5000 rpm it stops making power and the torque on the dyno sheet falls faster than a fat lady falls off a ladder. this is because the ecu pulls all the timing back to make sure it does not knock at high revs. Also the plug on the small port loom is differnet to a big port loom and so are the senors. hope this helps in some way
    Trev
    Queensland
    Redbank Plains
    10characters
    Bigport GZE was before the smallport...
  1. 4agze Knock Sensor
    By Roo. in forum Cars or Parts Wanted
    Last Post: 4th May 2009, 04:01 PM
  2. ae92 small port gze knock sensor, 4age alternator plug
    By Roo in forum Cars or Parts Wanted
    Last Post: 13th July 2008, 11:43 PM
  3. 4agze knock sensor
    By spaniel in forum Cars or Parts Wanted
    Last Post: 9th May 2008, 07:54 PM
  4. Need urgently, AE101 GZE Knock sensor or 7mgte Knock sensor
    By Nikkojoe in forum Cars or Parts Wanted
    Last Post: 23rd November 2007, 01:23 AM
  5. knock sensor 4agze map
    By cr86zy boy in forum Cars or Parts Wanted
    Last Post: 12th August 2007, 01:00 PM
