Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 31
Thread: Why is my car pulling to the right hard?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    Default Why is my car pulling to the right hard?
    Back from the shop, I got a print out of wheel alignment settings,
    There is nothing really too wrong that I can see from the print out.
    I had ps arms put in, Would my car pull if one of those are bent or something?
    I also had a lock spacer put in. I thought maybe the rack may not have been centred either. Could this also make my car pull to the right?
    Thank-you ! ! !
    FTP.
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    you have a locked diff and its off center?
    they aligned you car by centering the steering wheel and going from there?
    dont get a wheel alignment from there again? especially seeing as they didnt actually give you a wheel alignment, test drove it to see if whatever they did actually did anything, decided it didnt but charged you anyway.
    Senior Member Ae86sam's Avatar
    Manly
    Do you have both the right hand wheels on the car?
    sorry, couldn't resist..
  • #4
    Veteran driftke70's Avatar
    Ryan
    Buderim
    centered rack would mean you have more lock one way from center than the other, just poor alignment.
    wheelfriends.wordpress.com
  • #5
    Veteran 45KIDS's Avatar
    Brodie
    Toowoomba
    Go back and tell them to take it for a drive.
    Obviously they didn't test drive it. Or just slack cunts.
  • #6
    Senior Member resol's Avatar
    steve
    vic
    check tyre pressures first of all.
    maybe write up the spec from the print out?
    if the camber is out on the front it will make the car pull, if the castor is out it will make the car pull. not just the toe adjustment....
    take it back tell them its not right, ask them if they centered the rack. im sure they will redo it for you.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  • #7
    性交を愛する marvis's Avatar
    Whats the specs.
    Quote Originally Posted by trikzlane View Post
    I love streeting, Lowdown cars and watching the world unwind by every word Marv types.
    Quote Originally Posted by keiichi View Post
    dont you get raped by the police everywhere you go?
  • #8
    Mark
    yeah check tire pressure first, then maybe check your brake calipers to make sure one isn't sticking.
    Oh and you do have the same size wheels all round don't you?
  • #9
    Clinton
    Tweed Heads
    Printout is as follows;
    Rim diameter for toe values= 15 inch
    SETBACK:+0 02
    TOTAL TOE:-1.3mm
    INDIVIDUAL TOE: L:-0.7mm R:-0.5mm
    CAMBER: L:-2 33' R:-2 25'
    CASTER: L:+3 27' R:+3 19'
    KPI: L:+13 31' R:+12 32'
    INCLUDED ANGLE: L:+9 58' R+10 06'
    FTP.
  • #10
    Jonathan
    The caster is a little different either side, this is what causes pull to one side. It's not out by much, but maybe they could have tried harder to get it even.
    Your camber maynot be adjustable, but if it was, they could have tried harder to get it the same on either side.
    In my mind, the toe should be zero on all wheels. As a starting point at least.
    Also:
    -if you have coilovers they need to be adjusted all the same height.
    -the workshop should jack up each wheel when putting the W/A device on the wheel, and adjust for run-out.
    -you need the same size and brand tyres left and right.
    Plus, the workshop need to testdrive the car and have it driving straight before you get it back.
  • Page 1 of 4 1 2 3 4 LastLast
    1. Pulling down a 7afe engine - Removing crank bearing caps
      By Matt in forum Technical - Questions
      Last Post: 15th May 2012, 07:14 PM
    2. how hard would it be...
      By scott_22 in forum Technical - Questions
      Last Post: 22nd June 2009, 06:25 PM
    3. pulling gearbox out
      By wide s13 in forum Technical - Questions
      Last Post: 17th April 2008, 04:13 PM
    4. Car pulling to the right
      By -=GOODY=- in forum Technical - Questions
      Last Post: 29th November 2007, 09:56 PM
    5. Tips for pulling axel?
      By aaron_drift in forum Technical - Questions
      Last Post: 19th October 2006, 06:02 PM
