Results 1 to 3 of 3
Thread: RWD Water fittings for 4AGE
    Paul
    Default RWD Water fittings for 4AGE
    Hey guys,
    When I did the engine conversion on my sprinter, I ended up making custom water fitting which have ended up being a pain in the arse, so I am chasing a set of factory ones, or part numbers if you have them so that I can grab the bits from Toyota new (this is preferable).
    I am looking for the one the bolts to the back of the head, from drivers side of the head and the drivers side of the block as well at the thermostat and the other bits and peices.
    Paul
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    Have a full setup secondhand from JDM RWD 4ag
    PM if interested
    Trev
    Queensland
    Redbank Plains
    I did a faq when I bought all brand new rwd parts:
    16100-19095 - Water Pump & Back Housing
    11181-16030 - Water Outlet On Back Of Head
    16323-16020 - Thermostat Housing Outlet (Bottom Radiator Hose)
    16331-16020 - Water Outlet On Side Of Head (Top Radiator Hose)
    http://www.rollaclub.com/faq/index.p...a_Part_Numbers
    I also have a spare brand new bypass pipe (runs along the side of the block) that i have for sale.
  1. wtb: rwd loom, rwd exhaust manifold, rwd water components, rwd inlet
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 4th September 2011, 03:18 PM
  2. 4age rwd water set up
    By stefan in forum Cars or Parts Wanted
    Last Post: 20th December 2010, 11:45 PM
  3. Rwd water set up for a 4age
    By ta22 in forum Cars or Parts Wanted
    Last Post: 29th September 2010, 07:55 PM
  4. WANTED: 4age Rwd Water Pump Pully And Rwd Alternator Bracket
    By BIGPORT71 in forum Cars or Parts Wanted
    Last Post: 26th May 2010, 10:11 AM
  5. T25 to 4AGZE: Oil/water line fittings
    By PuGZoR in forum Technical - Questions
    Last Post: 21st June 2007, 08:26 PM
