Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 71 to 80 of 105
Thread: 7age basic build
  1. #71
    Veteran slydar's Avatar
    Dimitri
    sif. u prolly use bio-diesel.
  2. #72
    I think you guys already know the difference of "compression ratio" and "compression pressure"
    when using regular 88 octane, I never hit 5000rpm, because knocking on high rpm sometimes can't be heard and very dangerous. I never recommend octane 88 if you running 7age with 4age smallport piston.
  3. #73
    i believe, you will need TRD metal HG.it gives more peace of mind
  4. #74
    i am probabbly using a trd for that reason.
  5. #75
    E-Famous (Remeber your roots)
    My brother has one of these, bought it from Wide S13. Let the fun begin!
    marvis.
  6. #76
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    tell your brother to put some smallport pistons in to raise the compression to a reasonable level. im pretty sure wide s13's 7age was a standard 7a bottom end with 7a pistons, and a 4a head
    the standard 7a head gasket is metal and thinner than a standard 4a one. if you want a metal head gasket use a 7a one
  7. #77
    its got a 7a head gasket in it to lift it more than the trd one that was in it.
    any probs with the motor marvis let me know more than happy to help
    ae71 parts for sale stripping 3xae71's and a ke70
  8. #78
    Should be all sweet man. I think we will leave it as is and throw it in. Might get the cams off you though.
    Thanks,
    marvis.
  9. #79
    Moderator Sam-Q's Avatar
    Endeavour Hills
    whatever you chose dont use any 4age piston and a 7a gasket ok? the compression would be obscene
  10. #80
    Noted.
    Thanks,
    marvis the noob.
  1. Replies: 0
    Last Post: 17th September 2012, 11:51 AM
  2. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  3. 7AGE build - Give me your oppinion!
    By s3phro in forum Technical - Questions
    Last Post: 1st March 2011, 11:21 PM
  4. Visual Basic Anyone?
    By bigm in forum Offtopic Discussions
    Last Post: 24th September 2008, 09:28 PM
