Results 1 to 5 of 5
Thread: 4ac into ke70,
    Senior Member NathanKe70's Avatar
    Nathan
    Holden Hill
    Default 4ac into ke70,
    could i use the same wiring or would i need the 4ac loom etc.
    Smoke Tyres Not Weed, Fuck It Smoke Em Both.
    Quote Originally Posted by hendo View Post
    ahhh, AE86DC. i come for the cars, i stay for the porn.
    Jonathan
    You can use the same "loom" which consists of 1 wire to the starter, 1 wire to the oil pressure sensor/switch, 1 wire to the water temp sensor, 1 wire between the distributor and coil negative, ingnition wire to carby fuel switch, ignition wire to auto choke. That is about it, apart from alternator. They all have the same functions between both motors, very easy to do.
    Jonathan
    All the vacuum hoses and switches you can get rid of if it confuses you and the car is not going to be emissions tested. The only vacuum hose you "need" is from the base of the carby to the vacuum advance.
  • #4
    Nathan
    Holden Hill
    okay cheers for the info.
  • #5
    Calvin
    Kilsyth
    ke70 will work but lengths will vary. best to clip on the ae71 engine loom along with ae71 fuse box to make it easier. that wall all wires will be the correct length. are you changin your coil to the opposit side of engine bay?
  • Similar Threads
    1. 4AC into ke70.. need some help!..
      By timos in forum Technical - Questions
      Last Post: 25th August 2010, 08:00 PM
    2. 4ac into ke70
      By Kieran in forum Technical - Questions
      Last Post: 28th July 2008, 01:06 AM
    3. 4AC Choke in a ke70
      By ѕніс in forum Technical - Questions
      Last Post: 28th April 2008, 12:16 AM
    4. 4ac to ke70 conversion
      By Dave in forum Technical - Questions
      Last Post: 7th August 2007, 11:30 AM
