Results 1 to 10 of 15
Thread: ke55 plus sr20det equals drift slut yeah
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    Default ke55 plus sr20det equals drift slut yeah
    hey guys new project
    ke55 corolla complete with rust and spiders. free from my brother inlaws farm.
    sr20det black top standard engine.
    rb20 afm
    remapped computer and s15 injetors
    040 fuel pump.
    t3/t4 chinese turbo
    just the basics
    hopefull try get a hilux diff in there
    going to do this on a real chepo budget.
    suspension will be all sprinter shit shoe horned in. as i have my old shit lieing around
Name:	ke55 turbo bro (1).jpg
ID:	7535   Click image for larger version.
Name:	ke55 turbo bro (3).jpg
ID:	7536   Click image for larger version.
Name:	ke55 turbo bro (2).jpg
ID:	7537   Click image for larger version.
Name:	ke55 turbo bro (4).jpg
ID:	7538   Click image for larger version.
Name:	ke55 turbo bro (6).jpg
Name:	ke55 turbo bro (5).jpg
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
    Troy
    Gisborn
    i think i posted in wrong section i own a hachi aswell does that count. sorry in advance for people who will flame at me for this sorry
    Veteran bigm's Avatar
    Gold Coast
    very cool.
    will keep an eye on this.
    how tight is the tranny tunnels in one of these?
    Senior Member Zach's Avatar
    Zach
    Clovelly park
    Wirth
    I'm a fan! any more pics?
    秀はるかに勝つ!
    Troy
    Gisborn
    tonight i just converted the cable clutch to hydralic clutch.
    parts used
    ae71 clutch master modified pedal box added a bolt abit of cutting and bang there we have it
    you must remove speedo cable and open up the hole just a small amount.
    tunnel is tight nothing a hammer couldnt fix yaya. i had to cut the tunnel down were the shifter goes to get the gearbox to fit in the tunnel as sr20 gearbox is dam long.
Name:	ke55 clutch setup (1).jpg
ID:	7619   Click image for larger version.
Name:	ke55 clutch setup (2).jpg
    Gold Coast
    if u want it shorter use a RB20 box with a SR bellhousing.
    looks good tho mate.
    Troy
    Gisborn
    new update picked up some more parts for the ke
    044 fuel pump $80 special not bosch some cheapo brand should work fine tho.
    picked up sr20de will be putting 1.8mm steal headgasket and tap block for oil lines for turbo.
    some pictures of mounts and motor.
    sr20de radiator and hoses
    decided to use a rx7 cooler top mount had lieing around from when i bought my 13bt for my sprinter
    sr20 gearbox is really good for the length the shifter is in the best position.
Name:	ke engine mounts (2).jpg
ID:	7667   Click image for larger version.
Name:	ke engine mounts (1).jpg
ID:	7668   Click image for larger version.
Name:	new sr20 (1).jpg
ID:	7669   Click image for larger version.
Name:	new sr20 (2).jpg
    Troy
    Gisborn
    quick update
    radiator is in bolted up and hoses on.
    picked up some new parts todat got a damaged intercooler 600 by 300 by 90 has been hit but doesnt leak will work fine for free of O.H performance i work next door. the rx7 cooler wasnt going to work.
    scored a hilux diff out of a early hilux its the riht length for ke55 no shortening required drum brake. $200 yeah!!!!!!!!!!!!!!!!!
    Zach
    Clovelly park
    Wirth
    seems to becoming along nicely..
    秀はるかに勝つ!
    Troy
    Gisborn
    more progress
    got cooler in mounted and hidden sprayed black for ghetto spec.
    pulled my diff apart had a quick look its got 4.3 gears yo.gonna weld it for some lockage.the axles are massive.
    it is so close to striaght bolting on to the leafs slightly bigger u bolts and slight mods should fit
    cant get photos up want work.
  1. My New Drift Track Slut Booter Ae86 Levin
    By sc86 in forum AE86 Owners Forums
    Last Post: 5th April 2012, 09:24 PM
  2. Roco,s 1uz 86 drift slut build
    By roco in forum AE86 Owners Forums
    Last Post: 28th January 2010, 08:26 PM
  3. ke55 with sr20det unfinished project hilux diff
    By ae86-13b in forum Cars for Sale (Toyota Only)
    Last Post: 8th January 2010, 05:57 PM
  4. project panda drift slut
    By 1sik20valve in forum AE86 Owners Forums
    Last Post: 2nd December 2009, 10:23 AM
  5. Brendans Beams Powered Drift Slut
    By dr1ft-pig in forum AE86 Owners Forums
    Last Post: 3rd October 2008, 03:48 PM
