map sensored gze with stock ecu.
when cold it starts first kick but after it gets some heat into it,even the hot days this week itl crank fine and after say 10 or so seconds begins to start and even then it cofs and farts till im guessn the excess fuel clears cos i can smell fuel after it starts. after that clears it runs ok,has a slight miss sometimes on idle. doesnt pink no mater the weather or load.
ive taken the off coolant idle control valve but it was doing this before taking it off.
the guy i bought the motor off said,the guy before him may have had a ems stinger or somthn nasty on it when it was a gze. could the ignition timing been played with cos of the ecu?
a friend suggested maybe a weak fuel pump?? whats the fuel pressure meant to be at? 3 bar??
i have noticed that itl go better on half throttle than too the floor.
any other ideas?
