If you have a 20V sitting there and are keen then do it. It is possible and if done well should go damn hard.
The things to remember are:
- As mentioned, if you keep the quads AFTER the SC then you'll beed a blow off valve. Many people will tell you it's not good running throttles post-SC, but it can be done.
- You'll need aftermarket management.
- Think about your pulley sizes so you get a safe SC speed. From memory(hazy, best check yourself), an SC14 is "safe" up to around 10,000rpm, so you'll need a fairly low ratio to keep it under that if you're revving the motor to 9000. The pulley ratio has a direct effect on boost too, so it'll be a balancing act.
- Make some serious mounts for the SC.
Take a look at turbo 20Vs to get an idea of boost levels and plenums and so on. In the end going turbo may be easier, but there is nothing to stop you supercharging instead.
