Page 16 of 31 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 ... LastLast
Results 151 to 160 of 301
Thread: F series Diff info + Discussion
  1. #151
    West
    An f series is a toyota diff, not a borg warner.
    it has a 7.5 inch crown wheel. Is found in a tarago or old corona most commonly.
  2. #152
    Aug 2010
    Corey
    Brighton
    thanks mate look like i got done lol
  3. #153
    Veteran Skylar's Avatar
    Ken
    That's a stock diff.
    F is 27 spline 28mm.
  4. #154
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    So what does it take to convert the yr20 tarago f series to disk?
    I read the link in the first page and it only shows for all other f series, doesn't say anything about the yr20.
    Is the yr20's f series similar to one of the ones mentioned?
    All help much appreciated.
    bursting ovaries since 92'
  5. #155
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I'm guessing you mean YR22? because a YR20 has an E series.
    I'm pretty sure the axle flange is too large to fit the ST141/RT142 rear discs
    You'd possibly find that the MA70 disc brakes fit though, they fit on hilux's diffs and may have the same axle flange.
    Other than that, you can make anything fit if you get a custom caliper bracket made up.
  6. #156
    Mt Macedon
    Yep, I can confirm that the classic Corona disc rear end DOES NOT fit YR22 (2.2 litre EFI) Tarago F series.
    The YR21 and YR20 should have an E series. I've never checked it, but I'd look at either Corona setup or Golberg's link for discs on these. However you can't get an E-series LSD, so you're going to have to weld it or live with it open.
  7. #157
    West
    Just reporting to the thread what I learned today.
    I had the altezza torsen lsd centre fitted to the f series corona mk 2 housing.
    It was the type 2 lsd with the shafts parallel to the pinion, supposedly a strong design.
    Also, the diff shop did not use a spacer under the crown wheel as some have suggested. They were able to use a slightly different bearing and offset the centre on the adjusting threads. This way you avoid needing longer bolts, a spacer, and you avoid adding weight and a sheer point to the rotating assembly. Only took 1 day turnaround. I took it from fabricators to the diff shop midday yesterday, and got it back trued, cleaned, and assembled with new bearings and seals lunchtime today.
    Also it didn't have any baffles inside. I intend to fit some. Pretty much any f series bafffle should fit I hope. The cross over amongst every other F series model.
    Part 42108‑30010 (DEFLECTOR, REAR AXLE HOUSING OIL) was found on the following models:
    ©2012 ToyoDIY
  8. #158
    Jun 2009
    Blake
    Penrith
    Any one know how much power a yr22 f series can handle?
    Looking at getting a 4:11's one and I will be having around 300kws atws
  9. #159
    West
    300 kw is a lot of power. Might be somewhere around the limit.
    I know the general rule of thumb would be T series maybe 200hp and not too much torque. I'm not sure for F series, but then again the 8 inch Toyota Diffs are almost unsmashable, so how bad could a 7.5" be?
    Has anyone on this site Broken a F and how did you do it?
  10. #160
    West
    Just reporting back to the thread about the baffles above. They slid straight in like a glove. Even though the earlier housing never had them.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
