Page 18 of 31 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 ... LastLast
Results 171 to 180 of 301
Thread: F series Diff info + Discussion
  1. #171
    Member phil's Avatar
    Phil
    Sutherland shire
    Its ok I source a 4.3 centre so that will do nicely.
  2. #172
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    If anyone buys gears online make sure you get standard rotation and not the reverse rotation gears.
    As a side note i bought a 4.556:1 Yukon gear set from complete offroad for just over $300 and the quality looks every bit as good as the oem ones i pulled out.
  3. #173
    Veteran Konakid's Avatar
    Henry
    Eastern
    Anyone got a live axle centre around the 3.7 mark? Need one asap! located in Adelaide but ill get one posted for sure. Cheers.
  4. #174
    West
    I have the original live axle centre in good condition from a very well kept mk 2 rona rear end. Only 4.1 gears to go with it though, and without the gears assembled, just the loose centre n gears.
  5. #175
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    If you're desperate I might be able to scrounge a 3.9
  6. #176
    Henry
    Eastern
    Thanks for the offer dude but im really after a 3.7, i got a 4.1 atm and its way to short. Just turboed the 22r and dont want to rev it past 5500 ish so it lasts!
    Looked aorund and i need a 3.7 from an AUTO IRS RT142 or AUTO RA65. Will pay for shipping, cheers!
  7. #177
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    I'm looking for a 1.5-way diff for in my F-series axle from a Toyota crown MS112 ('79-'83) and I just want to double check some of the info I found so far.
    Can anyone confirm or correct the following;
    I have to look for a diff that will fit an altessa RS200 (SXE10) as that will fit into my diff as well.
    Best brands will be TRD or Tomei.
    Any other brands or model types that will fit a F-series diff? Also is it correct the Tomei diff will need a spacer ring machined up?
    Cheers!
    ADM AE86 Levin
  8. #178
    West
    You dont know if you need a spacer ring until it comes apart and you see the dimensions of the gears and bearings.
    Yes altezza lsds will fit, you can even use the stock torsen lsds from the altezzas.
  9. #179
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Currently using stick sxe10 torson LSD in an mx13 housing with no spacer. Didn't have any issues with fitting the center and clearance/meshing
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  10. #180
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Just for my understanding, where does that spacer ring go if i would need one? Between the bolted connection of the lsd and the crown gear?
    ADM AE86 Levin
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
