Page 19 of 31 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... LastLast
Results 181 to 190 of 301
Thread: F series Diff info + Discussion
  1. #181
    Eddie
    Correct. You will most probably not need it as there is adjustment you can play with to move the centre left/right. You will only need the spacer if you cannot set the backlash correctly because you run out of adjustment.
  2. #182
    West
    Yes and dont worry about making it up beforehand, if its required, any diff shop worth using can whip something up that will work great. I also built an altezza type 2 torsen lsd in an mx13 housing and it didn't require a spacer either. I used the 40 year old mx13 3.9 gears as they were extremely low mileage and parts of this era are generally great.
  3. #183
    Member gaspal's Avatar
    Richard
    Osborne Park
    anyone got info on F series diffs out of a 1986 cr21 tarago diesel? diff is advertised as 4.3 ratio, open centre, diff code: E282. looking at this for an ae86 that will be given the sr20 treatment...
  4. #184
    Veteran Konakid's Avatar
    Henry
    Eastern
    Its an E series not F series Hence 'E'282
    ONLY YR22 has F series code will be for example F232
  5. #185
    Veteran AJPS's Avatar
    Lonsdale
    e series are 7.1 inch
    strong but no lsds from memory
  6. #186
    Richard
    Osborne Park
    Duh well that was obvious... embarassing much! thx guys
  7. #187
    Senior Member adds's Avatar
    May 2010
    Adam
    St George
    Does anyone have a f series yr22 diff jig??? Or know of any drive line places that can change mounts over to ke70??
  8. #188
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Anthony kaizen garage do them
  9. #189
    May 2010
    Adam
    St George
    Cheers, I'm in sydney tho, but it still might work out cheaper to send it up.
    any idea how much he charges?
  10. #190
    Eddie
    Craft diffs in Granville can do it. Excellent work but be prepared to wait for it.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
