Page 2 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 11 to 20 of 301
Thread: F series Diff info + Discussion
  1. #11
    Mt Macedon
    I've dropped both an MA61 LSD centre and a Tomei Altezza centre into an MS112 Crown housing and pumpkin. Both went in and worked without issue.
    MS112 Crown diffs are cool. And MA61 rear calipers and discs (redrilled to 5stud) bolt up for ventilated rear discs.
  2. #12
    Veteran Konakid's Avatar
    Henry
    Eastern
    Great info!!
    Added.
  3. #13
    Senior Member Brenton 86's Avatar
    Brenton
    Roughly what yr models are mx13 cressida and yr22 taragos?
    ADM 4AGZE SPRINTER
    JDM SR20DET TRUENO COUPE
    ae86s love since 2004
  4. #14
    Anthony
    mx13 is late 70s, YR22 is 87-90
  5. #15
    Gone
    Joel
    Picton
    got pics of baffle design?
  6. #16
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Hrm, I've seen them somewhere, not sure where though.
    Its basically a thin bit of metal which curves around the centre inline with the circle which surrounds the diff head. Then it has a hole through each side for the axle (its two seperate baffles one on each side).
    Not sure if my word explanation helps there.
  7. #17
    Senior Member OMG866's Avatar
    Nick
    Miranda
    goin to open my yr22 f series diff on the weekend. so ill take some pictures of the baffles and post them up.
  8. #18
    Darren
    Leeming
    yep the f series have baffle plates before the diff tubes. just pressed steel sheet metal in the shape of the inner diff housing as goldberg said. S & Tseries also have this. also acts as a bit of a guide when inserting your axles to a minor extent. Will accept a Ma61 lsd centre no problem and also after market truetrac centres with no issues at all, this is for the YR22 centre. Fat axles, 7.5 inch crownwheel which is gimungus for a 4 cylinder. Enjoys boost, chomps on fried fish
    also wheel fitment will need to be reconsidered as it will be 20mm extra per side, which is no major problem as you can easily get 20mm out of your rear guards with flaring with a hammer.
  9. #19
    Henry
    Eastern
    More info added.
    Tarago YR22 - 4.1 and 4.3 - 1435mm
    Uses a G series (Hilux) diff nose tailshaft bolt pattern (60x60mm) All other F series is 55x55mm)
    Going to see if a Hilux G series rear half bolts up to the front half and is the same length as the RT142 Tailshaft ive got here.
  10. #20
    Josh
    Gunningbland
    Quote Originally Posted by Anthony View Post
    MX13 is '70-74
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 09:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 03:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 03:46 AM
  4. Info on F series diff ratios above 4.3
    Last Post: 12th June 2009, 03:16 PM
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
