The other thing you'll observe about the TCR10 Tarago diffs is not only are they a lot wider, they are also 5 stud.
I know that but I'm not concerned with finding one that is the same length, just a little wider is ok, for example a YR22 F series would be fine.
Is the centre the same tho?
Well they are still F-series diffs off the top of my head, so in theory yes. I've never tried using one though.
Just wondering, of the guys on here with mx13 rear ends, how many of you have kept the drums, and do they work well with the smaller (than an mx13) ae86 mc?
wheel cylinders look almost identical between the two so just swap the cylinders
mx13 = 19.05mm
ae86 s series = 20.64mm
Anyone know wheel bearing part numbers for yr22 tarago f series diff? Numbers on the bearings are 35bcd08lr but that also comes up as T series bearings. CBC told me TJ215BKIT would suit but wanna make sure. Can anyone confirm?
KIT2888
Hahaha, now I get why Seth has all this good info. Dude works at a massive auto parts wholesaler. Thanks for the answer bud.
Then how do u explain the ones that were already on there being the above numbers?
