Page 28 of 31 FirstFirst ... 18 19 20 21 22 23 24 25 26 27 28 29 30 31 LastLast
Results 271 to 280 of 301
Thread: F series Diff info + Discussion
  1. #271
    May 2010
    Looks the goods. I'm guessing if you go R31, you go same hand brake calipers too, or they the same as the VR ones?
  2. #272
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    Vr are drum handbrake so Better for the dedicated hydro. I've got a pair of vr ones on the car now for the trial while I rebuild the r31 pair.
    I'm waiting on a couple more sets of brackets to get cut.
    Unless you mean cables? I haven't hooked them up yet. I'm going to look at the r31 cables to see if they are usable.
  3. #273
    Veteran Konakid's Avatar
    Henry
    Eastern
    Registering interest now...
  4. #274
    Lindsay
    Mackay
    So I have a f series out of a corona mkii. My mate has a tarago f series, the flange is different hole spacing and the bearings are larger. Time to redraw the damn thing and get another test pair cut. So damn frustrating!
  5. #275
    Henry
    Eastern
    yeah the tarago is an odd one in the f series range ive heard. Thats what ive got.
  6. #276
    Lindsay
    Mackay
    I got my hands on a tarago f series to measure up. drawings completed and at laser cutters.
    I've test fitted both calipers and drew up a template that can be stuck to cardboard and cut out. Then placed in back of rim to check clearance.
    pm me if you want a pdf
  7. #277
    May 2010
    Any word my friend?
  8. #278
    Lindsay
    Mackay
    I've been really busy at work lately, moving house ect. Laser cutters have drawings but I'm not sure when they will be cut. I've sent a copy of the pdf to a bloke with ma61's to test the clearance but haven't heard back.
    I just bought a hoist eta tues so once that's up I can have a look at the cable situation.
  9. #279
    Veteran skizzamods's Avatar
    Oscar
    Adelaide Hills
    Looking at diff gears for my F-Series. Does anyone know if there are differences between the IRS and live axel CW&P's?
  10. #280
    Lindsay
    Mackay
    Yes. Irs the pinion gear is shorter.
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 08:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 02:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 02:46 AM
  4. Info on F series diff ratios above 4.3
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
