Page 9 of 31 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 81 to 90 of 301
Thread: F series Diff info + Discussion
  1. #81
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Where's the best/cheapest place for bearings , seals and gaskets Anddddd trd altezza LSD
    Yes I saw yours too assassin
    Will take pics of my attempt lol
  2. #82
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    what do you need buddy? i can have you a brand new TRD 2 way to your door for pretty much $1k brand spankers can have gaskets too if you need for a little extra
  3. #83
    Jack
    Blackmans Bay
    so anyone else keen on a TRD 2 way ?
    as per about 1k delivered brand new genuine
  4. #84
    Kaan
    Emerald
ID:	18388 here's our attempt . Just going to measure it and cut the mounts off with the plasma cutter today
  5. #85
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Did you space it up 1/8" or so so the housing is centered when you put the F-series on it after mocking it up with the T-series?
    Andrew
  6. #86
    Kaan
    Emerald
    Quote Originally Posted by assassin10000 View Post
    Andrew
    Spaced it up 8mm with the s series
  7. #87
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Cool, just wanted to make sure your ish would come out right
    Andrew
  8. #88
    Kaan
    Emerald
    does everyone use the s series brake line on the f series?
  9. #89
    Kaan
    Emerald
    Does everyone use genuine or aftermarket for bearings and seals etc???
  10. #90
    Jack
    Blackmans Bay
    maye we used the f series lines on mine as its the right length s series might not be,
    for bearings you need a specific width that would be very hard to find genuine so just go to a bearing wholesaler
    your TRD LSD should be in your hands very soon
  1. S and T series diff info
    By slide86 in forum Technical - Articles
    Last Post: 1st July 2016, 09:12 PM
  2. G series Diff info + Discussion
    By PRIMRK in forum Technical - Articles
    Last Post: 25th July 2014, 03:41 PM
  3. info on fitting rear 86 calipers to series 1 T18 diff
    Last Post: 29th April 2012, 03:46 AM
  4. Info on F series diff ratios above 4.3
    Last Post: 12th June 2009, 03:16 PM
  5. prize for this answer! s series diff info
    By styler in forum Technical - Questions
    Last Post: 28th November 2006, 01:50 PM
