Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 21 to 30 of 89
Thread: Buying mill/lathe tools.
  1. #21
    Veteran corknose's Avatar
    Callum
    i hate those things so in accurate. u push the tool post and cutts deeper.
  2. #22
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the Hercus or the chinese models? both?
  3. #23
    Callum
    i got no idea only used one and refuse to use again.
  4. #24
    Endeavour Hills
    ok did it look like the one pictured? because it shouldn't do that
  5. #25
    Timmy D
    North
    4age 20v? im sure that will fix the speed range!
    ever looked into a smithy lathe mill combo? aparently there pretty good for a home set up. i think you have to import them from the states which might cost though?
    JJ
  6. #26
    Endeavour Hills
    hahahaha, don't know about those, the problem with things like that is they end up being two compramised bits of equipment instead of one decent one.
  7. #27
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    What sort of money did you pay for the Hercus Sam?
    I generally keep an eye out on eGay, but there isnt much available.
  8. #28
    Endeavour Hills
    $700, from there I bought a new single phase motor- $150 and a new cross slide nut for $75. I am going to buy a 160mm 4 jaw independant chuck for it as it came with a decent amount of bits including a 125mm 3 jaw and interestingly an original self centering 4 jaw which is uncommon to say the least.
    Do a search for Lathe on ebay, select within 50km of your postcode and save your search. Patience really pays off here.
    What is driving me nuts is I have some brass rod thats 20.6mm in diameter which I want to machine down, however my headstock is 20.3mm. I think I will reduce the diameter down to 20mm at my tafe so I can use it, either that or chop it into 250mm sections so I can grab it in my chuck.
  9. #29
    Endeavour Hills
    Just remembered I also bought some change gears for around $150. If you want to cut metric threads then it's probably not worth getting a Hercus as the the change gears you will need will cost too much unless they come with it.
  10. #30
    Jul 2009
    Vic
    Yeah, these are the sort of prices i like. All the stuff over here is either the cheap Chinese stuff (C1/2/3) or $2k+
  1. lathe mill combos?
    By Tim.duncan in forum Tool Talk
    Last Post: 8th October 2009, 07:30 AM
  2. tools
    By evil86 in forum Cars or Parts Wanted
    Last Post: 19th February 2009, 11:36 AM
  3. tools what should i buy?
    By Gavin in forum General Topics (No Technical Questions)
    Last Post: 12th January 2007, 08:47 PM
