last pic is the correct way to measure since that is the clutch plate surface you want. you can use either one . what ever it measure up to either 200 or 212 buy the clutch kit to suit.
both flywheel would have the same outer diameter since all na 4age share the same outer diameter.
edit: 1st pic. those drill marks have been done to balance the flywheel and the larger holes again imo are for also balancing. smaller holes closest to the out side looks like locating pins for the pressure plate that must been taken out to accommodate whatever clutch kit is ran before.
oh tip: what ever one you decide to use .take the choosen flywheel it to the shop you are buying your clutch from and make sure the pressure plate fit/ lines up with the what ever locating pins that are on the flywheel. or they will need to be taken out and readjusted. shop can do that for you aswell.
