Results 1 to 10 of 12
Thread: How to install a Weber on your 4ac.
    Ade
    SYD, Inner west
    Default How to install a Weber on your 4ac.
    6 months ago I wasted what little monies I had (instead of saving it for a 4AG) and installed a Weber 32/36 on my 4ac boat anchor.
    So for you noobs out there wanting to follow suit here is how to go about it.
    Difficulty: Easy to average skill level
    Duration: couple of hours
    What you will need:
    - Weber 32/36 (or carbie of your choice)
    - Vice grips
    - Sockets/spanners
    - Weber adaptor plate/set
    - Rubber fuel line hose (from pump to Weber/Carbie, 30+cm)
    - 2 x Hose clamps for above mentioned fuel hose.
    - 10 grommets/plugs for blocking un-needed vacuum lines (may not use all, but good to have extras)
    - Gasket paper or gasket set.
    - Scraper/blade
    - Oil breather (optional)
    - Screw drivers
    - Angle Grinder
    I think that should cover it, though there maybe a few other things that I may have forgotten about.
    Installation:
    Step 1: Remove fuel cap and leave half on, this is to release pressure in the fuel lines. And battery Negative just for safety.
    Remove old & tired stock carbie and the 1500 vacuum lines, and block off fuel pump, so not to make a mess and/or set your pig on fire. Your intake manifold should now be bare.
    (Refer to picture, I removed everything not needed.)
    Clean up surrounding area and use scraper to clean off old gasket if deteriorated.
    Retain the heat deflector, plastic spacer with rocker return hose and some rubber vacuum lines
    Step 2: Using vice grips remove Carbie intake manifold studs, and replace with new ones provided in the adaptor plate set. Replace heat deflector gasket if needed, then re-install heat deflector.
    Install plastic spacer with rocker return hose, and then install adaptor plate/set.
    Then install Weber/Carbie gasket, then Weber/Carbie.
    Step 3: Using the grommets/plugs, block off all vacuum lines except the one that comes off the Weber/Carbie and Dizzy. Using the old vacuum hoses, connect the vacuum line from Weber/Carbie to Dizzy. And if possible purge the vacuum line form Charcoal Canister into an existing vacuum line.
    Step 4: Using an angle grinder cut off the Old throttle cable mount, then using a ruler measure the distance needed to mount the throttle cable off the brake booster bolt. With this measurement make a small cut and bend the modified bracket at a 90° to allow the connection of the throttle cable at the recorded measurement. (I choose to shorten my throttle cable to get a perfect fit, there is a place near Liverpool that can custom make you a throttle cable )
    Step 5: Install fuel hose from Weber/Carbie to Fuel pump. Connect rocker cover breather to 2nd Rocker cover outlet.
    Step 6: Re-install fuel cap and install Air filter. Reconnect battery and see if you can start it up.
    If you Weber/Carbie is not reconditioned, tuned (recommended) you will need to do so.
    (There is a guide to tuning your Weber/Carbie on the web which I will link when I find it.)
    More Picture to come!
    If I have left anything out, please let me know and I will add the missing info.
    Cheers, and enjoy
    -Ade Mc-
    AE86....robbing me! check the build.
    http://www.ae86drivingclub.com.au/fo...read.php?t=445
    Aaron
    In the Mountains
    while i was at it i also made a little aluminium plate i cut out and gasket to properly block off the exhaust gas recirculation. it was gummed up and didnt work anyway but what the hell.
    Veteran svenmate's Avatar
    Svenbot
    East
    Very good article. Thanks heaps!!
    AE71 Build Thread
    Ade
    SYD, Inner west
    sweet, is there any benefit in doing so? is that the pcv valve?
    Ade
    SYD, Inner west
    cheers, glad svenmate R&D approve, was going to add some astro turf in there somewhere
    Senior Member Dylan's Avatar
    Dylan
    So much cleaner without that rats nest of vac lines
    Dim
    Menai
    Thanks ade, I've been looking for an excuse to hook up my own webber. Was yours already jetted for 1600cc? Or did you take it somewhere?
    Ade
    SYD, Inner west
    i bought it cheap and had it recon'd at Carburettor Service Co. in burwood, cost around $250
    Junior Member viva's Avatar
    sam
    devonport
    Hey can someone tell what this is ? also i took my weber of like a month ago to clean it not knowing it wouldnt work again lol, so my car's screwed need to get it tuned or something .
Name:	car thingy.JPG
    waterhouse
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Talking
    oil breather
  1. 4AC Weber
    By Fusion in forum Car Parts For Sale
    Last Post: 2nd February 2010, 06:06 PM
  2. Installing a weber 32/36 on 4AC.
    By Ade_Mc in forum Technical - Questions
    Last Post: 20th August 2009, 06:08 PM
  3. possible to fit XF weber to 4ac?
    By Nic19 in forum Technical - Questions
    Last Post: 3rd April 2009, 07:12 PM
  4. carby install 4age - using 4ac setup
    By redsprinter in forum Technical - Questions
    Last Post: 14th February 2009, 07:18 PM
  5. 4ac weber adaptor plate
    By Julz01 in forum Car Parts For Sale
    Last Post: 25th July 2007, 06:29 PM
