Results 1 to 9 of 9
Thread: door mirror convertion
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default door mirror convertion
    can u put slanty fount/ ae71 door mirrors on my 81 flat frount drivers door or do i need a new door
    easy question i know but figure i thought id ask rather than buy 1 and find out it slightly different
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    just get a whole door, or try get another ke70 door mirror. the mirror off an ae71 is one built into the window sil, and a ke70 one is screwed onto the door. fairly sure it wouldnt work and im 90% sure that the glass parts wouldnt be the same either.
    FTP.
    性交を愛する
    Why? AE71 ones are ugly.
    You need to change the glass etc, So just swap doors.
    Veteran shift_rook's Avatar
    SE Burbs
    what marv said
    Veteran stahlz_ae86's Avatar
    Paul
    Short answer, Yes they can be changed.
    You don't need a new door. If you do plan on changing to the late style mirrors you will need to get the glass (as it is shorter to accomodate the mirror), the front rail that the glass slides in, the rubber thingy inside the rail and all the way around the glass and the mirrors.
    It may be cheaper buying a pair of doors for all those parts to make it cheaper than buying individual parts at the wreckers. Ask forum members for damaged doors may be the best bet as there's usually someone wrecking a KE. I just threw out an AE71 drivers door, but kept the mirror as a spare or to sell.
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    ^^^^ i can attest to this, thats how i did it, and if you wanna get really fancy u can use corona mirrors and have internal adjustment on both sides
    Paul
    Quote Originally Posted by sr_rolla View Post
    AE71 csx mirrors have the internal remote levers. If you want to get really fancy you can convert to Corona ELECTRIC mirrors
    See faq on rollaclub for detailed write-up with wiring diagram etc...
    Clay
    Barossa!
    cheers guys look in 2 that
    1 more question if i put a new drivers mirror will i hav 2 get 2 on either side? just if i need 2 go through regancy
    Paul
    If it didn't have a left originally I don't think it is necessary. Put one on anyway, they look shit with only one mirror.
  1. S.A 84 slant front drivers door mirror asap
    By 4ag te72 in forum Cars or Parts Wanted
    Last Post: 24th July 2012, 12:08 AM
  2. AE86 Drivers door mirror ADM
    By jet111 in forum Cars or Parts Wanted
    Last Post: 30th November 2011, 08:21 PM
  3. Wanted drivers door mirror
    By ae86rally in forum Cars or Parts Wanted
    Last Post: 25th August 2009, 05:05 PM
  4. wtb : ae86 door handle and door mirror
    By loc33e in forum Cars or Parts Wanted
    Last Post: 25th April 2008, 03:18 PM
