im doin some rust repairs and i need to remove the rear quarter panel window adn i wanted to know the easiest or best way to take it out
remove external trim ( very carefully without bending)
unscrew plastic clamps( take picture to remember order they go in, because they are colour coded)
cut around the glass with a long sharp razor blade/stanley knife ( best to use is the long ones with the break off segments)
if its got the factory foam type seal it will be easy to cut out, if its been dodged up with sikaflex/window sealant it will be tricky and time consuming
