wow those trumpets look sweet.
will definately be getting the adaptor and trumpets if i get a 16v.
Ae101 Stacks + 16v Quad adapter
this quads are the shit. Ive got them on mine just sound the best
burnouts are like jerking off, can be good from time to time, but there are better things to do with your penis.
Drews back! Yeww
haha, you used my quads as a reference picture, i feel honoured lol
hehe does the job just fine
Has anyone else had problems with the RX7 calipers hitting the Whiteline adjustable sway bar on lock?
On mine, without the T3 RCA fitted, the brake line hits the sway bar.
I have an unknown home-jobby caliper mount with 260mm discs.
seem the issue is not directly related to T3 products as the only component is the RCA's.
can i ask why you are concerned about it?
the brake line only hits without RCA's, i assume your car is lowers at least a little, so the RCA's should be fitted.
Can help you out, if you can post a pic it would help.
1. T3 Outer Tie Rod/Knuckle Kit
2. T3 tension Rods
3. ******* control arms
4. ******* coilovers
5. Stock sway bar.
Have a problem as you see in the PIC any similar occasion please ?
when it is all bolted up at ride height it should be fine
however those knuckles are horribly thick
plenty of better options to give more clearance
