Results 1 to 10 of 11
Thread: fuses in 86 engine bay
    Default fuses in 86 engine bay
    hey guys / gals,
    can someone tell me what these fuses are for
    the ones that are connected to the positive terminal on the battery
    all 3 please
    thanks
    Colin
    Veteran blair's Avatar
    Blair
    Sheldon
    follow where they go..?
    if it was only that easy....
    doesnt anyone have the cover that goes over the top of it
    to tell what they are?
    性交を愛する
    That's custom.
    no i dont think it is
    if you have a look on most jdm 16v engine bays they will have it
    i just cant get a good picture to see what they are
    Blair
    Sheldon
    just had a squiz at mine for ya mate, unfortunately theres no markings/writing on the covers at all
    and i dont have enough light to follow the wires all the way to the source.
    edit: take one out and see what doesnt work?? they are high values so they're possibly even fuses for the whole system...
    Edwin
    Colyton
    from memory in my AE86, the one with the 60amp value goes to the back of my alternator with the black plug. The other fuse, i think that goes to the fuse box next to your battery.
    From your photo, the taped up wired that run just above your cam gears cover would lead to your alternator.
    Well atleast mine did.
    But like everyone said, follow the wires.
    Hope this helps.
    thanks guys
    im just missing the middle fuse thats all
    just need to find out what they are for and what amps they are
    Daniel
    GC Hinterland
    i will take a wild guess and go
    one is alternator, one is starter and the other is accessories (goes to fuse box/es)
    Senior Member Simon-KE70's Avatar
    Simon
    30amp fuse from mem
    mine had one 60 amp and 2 X 30 amps.
  1. Engine Parts & Engine Bay Stuff
    By 44GTE in forum Just JDM Imports
    Last Post: 6th June 2009, 10:35 PM
  2. JDM 86 ENGINE BAY WIRING LOOM
    By orangechargd86 in forum Technical - Questions
    Last Post: 24th November 2006, 12:29 PM
  3. spraying engine bay
    By newby86 in forum Technical - Questions
    Last Post: 18th December 2005, 03:16 PM
