Page 12 of 30 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... LastLast
Results 111 to 120 of 293
Thread: Jonny's Levin GTV Twincam 20
  1. #111
    Trev
    Queensland
    Redbank Plains
    Quote Originally Posted by Jonny Rochester View Post
    Not much custom fabrication in these
    4A-C fuel return is bent to suit, but I am thinking the tube is very small.
    Jonny you should of went for the 4ac feed line for the return.
  2. #112
    Veteran Wally's Avatar
    Is thread is full of quality.
    Top work Jonny
    4AGE 16V
  3. #113
    Jonathan
    Delazy: your a dreamer. Order some massive cams for me.
    hachi_dk: It is a stock standard AE86 waterpump.
    Trev084: You are correct in this matter. May try that today.
    Meanwhile, I get flak for using second hand bottles. Everything costs money.
  4. #114
    lol...my builds only just hit 12 months...think ur cars been in the build process for quite sometime longer as has marks 3sgte car plenty of time for completion
  5. #115
    Jonathan
    Default Gearbox
    This is gearbox No.1:
    Standard T50 with the housings cleaned up and resealed with Toyota Red silicon, and new front and rear oil seals, new O rings on the speedo drive. New alloy washers on the plugs. Drain and fill plugs inspected and chucked out if rounded. (I don't like oil leaks). 4AG belhousing. TE72 clutch slave. New clutch fork rubber. TRD shifter. Regular GL-4 oil.
    I have both the TRD leather knob and the stock plastic one. The plastic one is lighter and probably more suited to racing.
    The speedo gears are 22:6 to suit the 4.3:1 final drive and 195/60R14 tyres. I also have 19:5 speedo gears which suit 4.3:1 final drive and 185/60R14 tyres. The AE86 in Japan could come with either, depending on tyres.
    I have a second gearbox and a full set of new syncros, but I will only use them as needed because they cost money.
    Clutch:
    I have a bunch of old clutches. I put in a 200mm flywheel with a second hand TRD 3 puck, but I have a feeling that will change soon.
  6. #116
    Veteran slydar's Avatar
    Dimitri
    output shaft spacer size checked?
    78's
  7. #117
    Jonathan
    Brandon swaps over the fuel line.
    Oil cooler:
    The AE86 came with a oil cooler in America and Europe, and the 3 captive nuts are there in the chassis to mount it. Rather than drill holes, I have used the same nuts to mount my oil cooler. My cooler is from a AE92 (or AE95) of course, and the way I mounted it I didn't have to change the AE92 bracket too much. The correct oil lines are 10mm, but I figured 3/8" fuel hose works the best.
  8. #118
    Oil cooler:
    nice work there jonny looks heaps neat
  9. #119
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    wow man, love your work
    if only i had the money to do a full resto on mine
    MY JZX83 (clicky)
  10. #120
    Adam
    South Eastern
    i have been umming and arring about starting my build or selling my shell, this thread just decided that for me.
    love the detail and the stockness very few people actually pay any attention to trying to get a job as factory as possible
  1. 20 dizzy with cas cover,twincam wheel
    By thr55t in forum Car Parts For Sale
    Last Post: 13th July 2011, 03:59 PM
  2. Original GTV Levin Stickers
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 2nd July 2010, 02:18 AM
  3. Rolands Original GTV Levin
    By RolandGTV85 in forum AE86 Owners Forums
    Last Post: 11th March 2009, 09:36 AM
  4. Tysons white levin gtv
    By Hally in forum AE86 Owners Forums
    Last Post: 21st September 2007, 10:39 AM
  5. MY JDM GTV LEVIN
    By krumpet in forum AE86 Owners Forums
    Last Post: 20th October 2006, 01:04 AM
