Page 15 of 30 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... LastLast
Results 141 to 150 of 293
Thread: Jonny's Levin GTV Twincam 20
  1. #141
    Jonathan
    The radiator looks good. Same item for 3A-U or 4A-GE or 4A-C.
    According to TRD, the auto one is rated at 26,500kcal. Maybe the aftermarket rad company thought they could achive that with a single alloy rather than the twin copper core.
  2. #142
    Veteran Nikkojoe's Avatar
    Tom
    Possibly could have a higher fin density than the genuine ones, but its probably cause it was cheaper to make.
  3. #143
    Jonathan
    Default Dash
    How it looks now.
    Painted the dash pannel matt black.
    Fitted the heater. I put new foam on a couple of joints. Non A/C duct from a AE71.
    Hand brake lever is the disk brake item (slightly different in lever ratio, and softer handle).
    TRD short stroke shifter, standard knob.
    GT throttle pedal.
    Dash cut to suit roll cage.
    Key turns and cranks the motor!
    Very rare steering wheel for a AE86 Trueno Black Limited.
  4. #144
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    very nice jonny but would it not be better to build to original specs ? u have so many nice new original parts and doing things like factory but factory never fitted a cage or 20v
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  5. #145
    Jonathan
    If I wanted a GT-Apex, I should just buy one and drive it around. It would make a OK daily driver, but not too different to my 1985 Subaru (for normal driving, unless you did skids).
    With the AE86, I am building what I want or course. It is all modular. The 16v will swap into it no problem. And for a race car the Australian spec shell works well because it is already lighter and simpler. Lighter wiring harness, only 1 horn instead of 2, no climate control etc... And there is no existing EFI wiring so you get to start from scratch.
    For any competition in Australia, the cage is needed, wether it's a standard car or not.
    The whole factory original parts thing is for a few reasons. The standard parts work quite well if you know how to maintain a car. And even "JDM" or new parts often work out cheaper than modifyed or "racing" spec parts.
  6. #146
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    love this bus
    no jive talkin stuff about needing to be JDM or whatever
    just building it how you want it.
    i tip my hat to you good sir
    NEAR MISS
  7. #147
    Jonathan
    Yeah thanks.
  8. #148
    Senior Member aaron's Avatar
    Aaron
    NOR
    is the dash panel a nightmare to get to (paint) if the windscreen is in?
    i wanna do mine now lol.
    wat paint u use for sun protection?
    car looking very nice btw
  9. #149
    Jonathan
    It would be hard with the windscreen, but my car has no glass as is. Part of my painted area would be behind the glass.
    I just used a matt black can that was laying about. It happened to be VHT acrylic enamel.
  10. #150
    Paul
    Looks like its coming together nicely and at a decent pace, looking good
  1. 20 dizzy with cas cover,twincam wheel
    By thr55t in forum Car Parts For Sale
    Last Post: 13th July 2011, 03:59 PM
  2. Original GTV Levin Stickers
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 2nd July 2010, 02:18 AM
  3. Rolands Original GTV Levin
    By RolandGTV85 in forum AE86 Owners Forums
    Last Post: 11th March 2009, 09:36 AM
  4. Tysons white levin gtv
    By Hally in forum AE86 Owners Forums
    Last Post: 21st September 2007, 10:39 AM
  5. MY JDM GTV LEVIN
    By krumpet in forum AE86 Owners Forums
    Last Post: 20th October 2006, 01:04 AM
