Page 16 of 30 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 ... LastLast
Results 151 to 160 of 293
Thread: Jonny's Levin GTV Twincam 20
  1. #151
    Jonathan
    I will be driving it around in the yard shortly, with no doors. On the road is another matter.
  2. #152
    Senior Member klusio's Avatar
    Kieran
    its got side intrusion why worry about putting doors on it
  3. #153
    Jonathan
    EFI fuel tank arrived today from Just JDM Imports. Very good price and timing. As you know it has the metal bucket and tube spot welded to the base, otherwise the same as a 4A-C tank.
    I got the fuel pump from ebay in Canada a few years ago. Took about 8 months to come, but arrived eventually. It screws into my new fuel lines.
    Still havn't made the front water housing, but with the standard radiator hose in place it makes it very easy to see what I have to make.
    ECU is bolted in. Most wiring is done.
    I once read a shocking report that stated 95% of all 20 valves pictured on the internet were incomplete and would not actually run even if you turned the key.
    How it looks now with race seat.
    The fuse box in the engine bay has a spot for the EFI fuse and relay. It was 4A-C spec but I have all this sused out and working.
  4. #154
    Veteran Nikkojoe's Avatar
    Tom
    You will find that the ae82 4age ones will be setup with the same board. I figured out which pin is the output pin on the EFI Main relay on my 86, if you want I'll go and have a look at what it was.
  5. #155
    Jonathan
    Thanks, but I already have it worked out. Plus fuel pump relay etc...
  6. #156
    Moderator Sam-Q's Avatar
    Endeavour Hills
    looking good, I like your fastener philosphy Jonny, I really wish I could buy M8 bolts with a 12mm head at the bolt place instead of the usual 13mm, same goes for the M10/15mm.
  7. #157
    Senior Member dave2221's Avatar
    agreed.
    there are a few ways to do things, and its the little details that seperates a good car, from a great car
  8. #158
    Jonathan
    If you buy the Champion bolts in the plastic containers hanging up at Repco, and get the bolts with the flange head, the M8 ones do have a 12mm head. You can buy bolts from the Toyota dealership also, but use part numbers off a more modern car because the old ones have superceeded numbers. I havn't actualy done that, I have enough bolts laying around. I may write a little article describing Toyota part numbers for nuts and bolts, and how to tell the size and length. That would be fun wouldn't it.
  9. #159
    Endeavour Hills
    yeah but arnt they still a shitty grade 5 bolt?
  10. #160
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    hey m8 a question for the oil cooler apparently these work on a low pressure system and do 1 5th of fuck all what is your opinion on this as i am running 1 on my build and want to know if its actually worth up grading
    mat
    the dyno pull to 300rwkw
  1. 20 dizzy with cas cover,twincam wheel
    By thr55t in forum Car Parts For Sale
    Last Post: 13th July 2011, 03:59 PM
  2. Original GTV Levin Stickers
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 2nd July 2010, 02:18 AM
  3. Rolands Original GTV Levin
    By RolandGTV85 in forum AE86 Owners Forums
    Last Post: 11th March 2009, 09:36 AM
  4. Tysons white levin gtv
    By Hally in forum AE86 Owners Forums
    Last Post: 21st September 2007, 10:39 AM
  5. MY JDM GTV LEVIN
    By krumpet in forum AE86 Owners Forums
    Last Post: 20th October 2006, 01:04 AM
