Page 22 of 30 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 LastLast
Results 211 to 220 of 293
Thread: Jonny's Levin GTV Twincam 20
  1. #211
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    yes maybe, ive only ever noticed the one standard vent hose that goes to the manifold but then vents to the intake just infront of the throttle plate therefore not making it a pcv system, only a vent system
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  2. #212
    Jonathan
    I found a full set of OEM style fin wheels. They are 14" x 5-1/2" and came off a "JDM" Toyota vehicle. After a clean they will make good daily driver or drift wheels. It makes a good spare anyway with 185/60/14 tyre, and fits over the Mazda brakes.
    My good wheels are still the 3 piece Rays Volk fin wheels. 14" x 6-1/2".
  3. #213
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    that interior looks really nice, i like where this project is heading! should be good to see it in action
    Andy
  4. #214
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    i guess i am having the same problem as you may i ask where these screws are on the throttle?
  5. #215
    Jonathan
    You probably have to take the trumpets off to see the screws. There is 1 screw on each throttle body. You use a stubbie flathead screwdriver. From factory, the head of the screw is a fair way down the hole. I found I had to undo all 4 of the screws a fair way, intill the head of the screw was flush with the surface. Then the motor can idle with the throttles closed, and no idle speed motor used.
    It is a air bleed screw which lets air past the throttle, and adjusts idle speed. It's the same as on all EFI cars, only in this case there is 4 of them.
  6. #216
    Senior Member aaron's Avatar
    Aaron
    NOR
    how do you plan to resurrect your door trims with the gaping speaker holes?
    or are u getting others.
    83' 4AGTE Hachi - 335whp @ 22psi on United E85.
    Never ending build...
  7. #217
    Mark
    i like how you've mounted the adaptronic jonny, but i can't believe you haven't put an original JDM stereo in there! hahaha
    I'll have to show you what i did with my adaptronic when i got sick of it hanging out of the glovebox when you fix my water pump seal for me
  8. #218
    Jonathan
    They are speed holes for ventilation and extra speed.
    Maybe a round bit of plastic? Icecreame bucket?
  9. #219
    Jonathan
    Default Under car
    Fullhouse factory inhouse custom "Azcustom" team racing exhaust system. Only members of the actual Azcustom racing team get the matt black version. 2.25" TIG welded mandrel bends.
    Let me indulge in more pics of my own car. Some surface rust in places.
    I now have 30mm Roll Center Adjusters.
  10. #220
    Jonathan
    I have some no-name front tie-rods with a rodend for the joint like many of us have. If you use the normal bolts and washers that they come with, the bolt head can hit the steering knuckle, limiting steer angle. I have gone back to the factory style stud as pictured. These studs happen to be from a Camry strut top. If the knurl is not tight, MIG weld them.
  1. 20 dizzy with cas cover,twincam wheel
    By thr55t in forum Car Parts For Sale
    Last Post: 13th July 2011, 03:59 PM
  2. Original GTV Levin Stickers
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 2nd July 2010, 02:18 AM
  3. Rolands Original GTV Levin
    By RolandGTV85 in forum AE86 Owners Forums
    Last Post: 11th March 2009, 09:36 AM
  4. Tysons white levin gtv
    By Hally in forum AE86 Owners Forums
    Last Post: 21st September 2007, 10:39 AM
  5. MY JDM GTV LEVIN
    By krumpet in forum AE86 Owners Forums
    Last Post: 20th October 2006, 01:04 AM
