Page 3 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 293
Thread: Jonny's Levin GTV Twincam 20
  1. #21
    I look forward to the next chapter
  2. #22
    Senior Member grantobius's Avatar
    grantobius
    nsw
    newy
    aus
    Default hey
    with ur bottom water outlet on your water pump,with my 20v l had clearace issue and the hose was rubbing on alternator. You may have already done something to avoid this but a ae82 thermostat housing works great, it has hole for a temp sensor which l just plugged up but it comes out on a better angle.
  3. #23
    You can use that hole for the original fan switch thermostat, if you wan't to run an elec fan that is.
    It does appear to be a genuine brand new AE86 thermostat though. Maybe Jonny can shed some light on this situation ?
  4. #24
    Jonathan
    I use a genuine AE86-4AGE thermostat housing, so I don't expect any problems. Everything in that region of the motor is AE86-4AGE parts. You get problems when you start to mix and match. The only part Toyota don't make is the top water outlet for a RWD 20 valve.
    AE82 and AE92 have 4 different water temp sensors. I only need 2, which can both be in the heater fitting on the back of the head. (May try a AE82 item if someone has a spare).
  5. #25
    They only differ in plug type, and the ae82 type is the one you want right ?
    (say yes, you will get 200 points)
  6. #26
    Daniel
    GC Hinterland
    looking good mate i have done the alt/thermo housing same as you. Would like to see how you do the top water outlet, thats the last bit i need for my conversion!
    Daniel
  7. #27
    You can modify it so it comes out in a stockish position. For me it was quite close to the alternator but that is only because I retained a FWD setup.
  8. #28
    grantobius
    nsw
    newy
    aus
    well l used the rs chita kit and all genuine jdm bigport stuff aswell
  9. #29
    Jonathan
    Oil cooler:
    In Japan, none of the Corollas from AE86 to AE111 were fitted with a factory oil cooler. In Australia and Europe most Corollas have a factory oil cooler, even the 4A-FE ones. I believe if the 20v were sold in Australia, it would have had the oil cooler. The AE86 did have a factory oil cooler option in Europe. It used the same oil filter valve body as the AE82/AE92/AE101/AE112.
    I went and got the setup from a AE92 at the wrecker.
Name:	my 20v 025.jpg
    I drilled a 12mm hole in my sump in the same location. I welded a M12x1.25 nut on the inside of the sump. It looks factory.
    The only problem is the top banjo fitting is on a funny angle, too close to the engine mount. On the Europe AE86, this was a straight fitting, not a banjo.
    This pic shows a RWD 4A-GE with factory oil cooler setup. You can just see the straight fitting, gold in colour. This part is hard to get so I will just make it.
    Made it in aluminium. No one wanted to sell me hex bar.
Name:	cooler block.jpg
    Of course the TRD Bible shows every one of their setups with either a full flow high pressure oil cooler using Earls stuff, or a dry sump. I went and bought the Earls addapter and fittings and cooler. But I got frustrated because you have to find a combination of parts that clear the block and everything else. The rest of the car is 98% Toyota so may as well keep it that way till I have a real problem.
    And ask yourself this, how many Earls fittings in red and blue with braided hose do you find on the R35 GT-R? Problably non.
  10. #30
    Jonathan
    Roll over protection: Schedule J
Name:	my cage 019.jpg
    Sorry, there is nothing JDM about my roll cage. Pretty much a bare minimum cage with reference to the CAMS manual, and some thought to rigidity, and keeping it lightish.
Name:	my cage 002.jpg
Name:	my cage 003.jpg
Name:	my cage 004.jpg
    The AE86 is not a fast car. It is a light fun car used for training and practice. So no need to go overboard with heavy tubes.
    Roll cage is pretty much finished now. The good welds are done by Aaron Martin, who builds a fair few cages on the side. (I did the bad welds). You will see much better when its painted. Now I have to clean everything ready for paint.
    I have to hammer out some dents in the bonnet. To make this possible, I am thinking of cutting all the support webbing from under the bonnet. What you think?
  1. 20 dizzy with cas cover,twincam wheel
    By thr55t in forum Car Parts For Sale
    Last Post: 13th July 2011, 03:59 PM
  2. Original GTV Levin Stickers
    By RolandGTV85 in forum Cars or Parts Wanted
    Last Post: 2nd July 2010, 02:18 AM
  3. Rolands Original GTV Levin
    By RolandGTV85 in forum AE86 Owners Forums
    Last Post: 11th March 2009, 09:36 AM
  4. Tysons white levin gtv
    By Hally in forum AE86 Owners Forums
    Last Post: 21st September 2007, 10:39 AM
  5. MY JDM GTV LEVIN
    By krumpet in forum AE86 Owners Forums
    Last Post: 20th October 2006, 01:04 AM
