I would still like to see some pics of your setup
last night i re did it so the linkages run off the other side of the carbs, its that big round thing with holes in it thats the problem lol, but even without that the threaded shaft that it bolts onto very nearly fouls, i think i can fix it with a flapper disk to my water outlet its sooo close
Hmm, havent really seen a linkage setup like that before. I've found some other setups though
yea right, mine seems to be working good now, quite happy with its, took some work to reverse it all though. Does the ae86 throttle cable normally fit?
I had to use a ke70 throttle cable with mine, stock 4ac one too short.
Good to hear its working out for you
getting them running right, that could be another thing lol
Ok so I know this is a bit of an old thread, but I'm going down this path with my 4age and I was wondering if anyone has come up with an alternative ignition setup yet?? Can MSD be used or even an XR400 fireball electronic ignition setup?? Just curious is all
