Results 1 to 10 of 48
Thread: 4age carb how to?
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    Thumbs up 4age carb how to?
    Ok, so i've been contemplating the use of carburetors on a future build and summing up think it's a good idea. carbs= no overly expensive management, good response with the right tuning, easier (don't quote this though) to tune than an ecu, and you still get to hear that sweet sweet induction noise without mucking around with ITB's. converting a 4age to carb sounds relatively straightforward and I'm sure a couple people have done it on here so please show a run through of how to convert to carb.
    oh, and i like pictures
    thanks.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
    Senior Member Dylan's Avatar
    Dylan
    Not overly hard to do.
    What you'll need:
    A manifold. Redline make these ready to go to suit sidedraughts for Big and Smallports
    You'll need to thread the injector ports, and block them off
    You need a low pressure fuel pump,and regulator (around 4psi)
    Then you need to think about the ignition setup. Couple of options : A brand new distributor made to suit with centrifugal advance, or use the standard distributor with this
    and then playing around with setting up the linkages.
    I'll post up some pics, any more info you need?
    Dylan
    I haven't got any pics of it going together though unfortunatley.
    The manifold doesn't come with any mounting hardware, so I had to source studs.
    Theres probably a few things i've missed, If you want part numbers for stuff PM me
    Here a few links that I found helpful:
    Davey & Riki-lee
    South Australia
    Seaford SA
    Good thread
    Our introduction - Click here
    todd
    might also be worth looking into if your collecting up bits for a carb setup.
    Veteran shift_rook's Avatar
    SE Burbs
    dylan your carb setup wins so much, so damn tidy
    Dylan
    Thanks Chris
    Senior Member KENut's Avatar
    Sep 2009
    B-unit
    ACT
    canberra
    What about carb choice?
    I worked it out a while back, I reckon ideally you'd have 43mm throttles (from memory). From a choice of either 40mm or 45mm dellortoes, which would be better? Better low end with 40's, better high end with 45's?
    I guess what I'm saying is, could you use 40mm dellortoes if you werent after high revs
    Dylan
    40 seem to be fine for use with standard cams, 45s for aftermarket cams. Depending on the jetting
    Sep 2009
    B-unit
    ACT
    canberra
    Cheers Dylan, makes sense
  1. 4AGE twin carb conversion help
    By Undeez in forum Technical - Questions
    Last Post: 30th November 2012, 06:00 PM
  2. Carb 4age - engine dieing
    By Deeken in forum Technical - Questions
    Last Post: 23rd October 2011, 06:18 PM
  3. Quad carb/twin carb on 4K?
    By Hazzard in forum General Topics (No Technical Questions)
    Last Post: 16th March 2010, 10:33 AM
  4. Carb'd 4age Corolla ae71
    By Course_Out in forum Cars for Sale (Toyota Only)
    Last Post: 4th February 2010, 07:22 PM
  5. 4age carb'd
    By driftae71 in forum Technical - Questions
    Last Post: 16th July 2007, 08:35 PM
Tags for this Thread
