Results 1 to 8 of 8
Thread: Front swaybar. AE71 to AE86?
    Jonathan
    Default Front swaybar. AE71 to AE86?
    Does a KE70/AE71 front anti-roll bar fit a AE86? If so, the fatter bars from a KE70 wagon or van would fit a AE86. Anyone?
    Quote Originally Posted by Jonny Rochester View Post
    Had a look at putting a sprinter one in my KE panelvan. They looked quite different in the bends, so I would say no (plus I then realised mine was probably stronger anyway). However I didnt actually pull them out so I cant be 100% sure.
    Senior Member Simon-KE70's Avatar
    Simon
    i have an ae86 one in my KE70 if that helps
    性交を愛する
    Whats the diameter of them?
    Veteran slydar's Avatar
    Dimitri
    strange, i would have said yes.. same lca? and i would have guessed same tension arm? if thats the same the other stuff should be, except maybe the brackets, as the ends of the chassis rails and tie rails to appear difference (but may be dimensionally the same).
    ill admit im guessing though.
    Simon
    marvis: not overly sure, if i had my car here i would go measure it
    Trev
    Queensland
    Redbank Plains
    I have a set of sway bars and a panhard rod here from an adm ae86 if you wanna buy the front sway bar.
    Jonathan
    Front sway bars:
    AE86 21mm
    AE85 20mm
    KE70/AE71 wagon 22mm
    KE70/AE71 van 23mm
  1. Standard ae86 front swaybar
    By SHADOW KNIGHT in forum Melbourne & Vic Events and Discussion
    Last Post: 19th May 2011, 08:45 PM
  2. New front swaybar AE86
    By jet111 in forum Cars or Parts Wanted
    Last Post: 11th April 2011, 09:43 PM
  3. AE71 or AE86 rear swaybar parts
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 13th September 2010, 10:49 AM
  4. Ae71 good swaybar sizes + vn swaybar
    By tc-rolla in forum Technical - Questions
    Last Post: 7th February 2010, 12:24 AM
  5. AE86 aftermarket front swaybar
    By Clint in forum Cars or Parts Wanted
    Last Post: 31st August 2009, 04:06 PM
