It increases the length of your rack. Yeah it does add masses of toe in but that's why you adjust the tie rod ends to your desired specs.
I highly reccommend them. Easy to install too.
hi guys, basic question so i didnt use the template.
how does a lock spacer improve lock?
wouldnt it just give you toe on one side?
cant quite comprehend it so any help is welcome.
cheers guys.
As Sven-dog said... it increases the length of the rack, you can allow for the toe but adjusting the length of the tie rods/ends
I have a lock spacer, with T3 Super lock knuckles and tie rods/ends with 2 settings, and on the outer hole (Power steering knuckle length) I have huge amounts of lock. One of the best mods you could make IMO. Lock spacer and P/S arms.
Ive since moved them in to the other set of holes (Essentially shortening the knuckle, and even with a fucked alignment, I have super-mega-demon lock.
yer i get it now,
im setting up my mates front end with lock spacer, sigma LCAs, camberplates, pw/s arms and what not; i wasn't looking hard enough into the actual sizings of the lock spacer,
i realized that there is a machined section that can slide into the rack therefore extending the rack.
im setting up my front end this week with the t3 (2 hole) pw/s arms, jonny's extra lock rack ends on a powersteering front end so ill see how that comes up!
been told that lock spacers cannot be used on pw/s setups but i checked on my car (bcoz my car has pw/s) and the lock spacer did fit, only reason that i can think of lock spacers not being recommended for pw/s setups is because they can over-extend the rack and burst the seals?
anybody care to explain whether im right or wrong?
i asked AJPS a while back and David (forget the name) said simply that they are not for pw/s soo hmmm....
also, ill post pics of the lock of my powersteering front end soon.
With your mates car and the sigma arms, you'll need RA60 celica Tie rods and ends, or adj. rod tubes, because the 86 tie rods and ends dont have enough adjustment.
i took that very setup off my car a month or two ago.
yer cheers for that.
got some already
how do you reckon that setup went for you?
that setup was from my brothers car and was very responsive, only thing was his lock spacer wasnt put on right and he had fuck all lock to one side. but overall VERY GOOD
Dunno. Changed it before I drove hard on it. Had revolver coils, P/S Arms, Nobybooth tie rod tubes, RA60 TRE's and 25mm RCA's. I can only imagine it wouldnt perform as well as my current setup.
I have BC Coilovers, Buddyparts 40mm RCA's, T3 knuckle/tie rod/rose-jointed end combo, Buddyparts rose-jointed Adj. LCA's and Lock spacer, Whiteline swaybar and a rebuilt steering rack, and it's brilliant. Was so stoked with how it felt first time out... even with a shitty "9pm the night before racing" eye alignment.
Just need to finish off the rear end and Im good to go.
ahh alrite,
my setup is
t3 adjustable LCA's,
t3 knuckles,
t3 tie rods/end,
cusco camberplates,
ae86 stock castor kit
some jap coilies with trd greens that appear adjustable?
jonnys extra lock rack ends,
power steering - which no one seems to run
in the rear ive got t3 traction brackets,
AJPS adjustable panhard and stock 4 links,
havnt drived with any of this yet as i got it all after i blew my diff.
cant wait to test it, sounds similar to your setup so should be great!
Yeah, I have adj. panhard/traction brackets etc too, Ill be running a T3 4 link, Whiteline rear sway and T3 Panhard rod soon. Slap some 195/50's on my 10's and Im good to go.
Good Luck with it.
another question, why do you only run 1 lock spcer on pax side n why not another on driver,, so you have 2 on the rack. wouldnt increasing in rack increase lock?
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
