Results 1 to 8 of 8
Thread: BT 20V balance
    Member dodgybrooks's Avatar
    Stephen
    Townsville
    Default BT 20V balance
    Gday, I'm looking for some advice. What is the balance like of the rotating assembly in a BT 20V? I've currently got mine apart with the heads off getting ported and was wondering whist I'm at it should I balance the pistons/rods? The engine is for street use and will have the standard ECU so won't be revving over the stock redline. Would I notice a difference if I took the time and did it, or are they pretty well balanced from the factory?
    I'm not looking for mad power, more something that will be fun and won't blow up. It's done about 100k and was running fine in it's previous FWD existence.
    Jonathan
    If no machine work is being done to the pistons or rods or crank or flywheel, then there is no need to get it re-balanced. What is the rev limit of the 20valve? What is the rev limit on your Mums car? Compare the two. The 20valve is probably the better built motor right?
    You are going to the trouble of porting, with stock ECU on the street? Not sure what the gains would be. Better money spent on new rings and bearings.
    Senior Member Simon-KE70's Avatar
    Simon
    hang on... it was running fine, and you plan on retaining stock ecu and stock rev limit
    so why did you pull it apart?
    not being rude, just curious. toyota built them right from the factory you know... no need to do anything to them unless its a genuine reason like worn rings
    Jonathan
    But Japanese motors don't get serviced, and are covered in black slim inside. Getting that cleaned out would make me feel better.
    I recon a light valve regrind, new stem seals, new rings, new oil seals, and it would go like new.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I was under the impression that there still was room for improvement in the balance of any 4age engine, any thoughts?
    Stephen
    Townsville
    Has anyone taken out and weighed and balanced the stock pistons/rods or the crank? A mate of mine who runs a workshop in Japan says he has seen 4As with 10 grams of difference between the pistons/rods and thinks a balance would make a bit of difference, but the engine builder here recons there is no point with the stock ECU and rev limit. I'm just looking for an excuse to do it, also be able to change the rings at the same time....
    Quote Originally Posted by Jonny Rochester View Post
    Yea that was the idea, give it an overhaul to make me feel warm and fuzzy. I've got new oil & water pumps, timing belt, cleaned the heads (ports were a mess thus the port job) and all new seals & gaskets.
    Mason
    Salisbury East
    Hey mate
    There's no point rebalancing as they are balanced well from the factory
    and the rev limiter is around 8800.
    Engine machine shops aren't interested in balancing secondhand parts
    anyway. If it has that black gone off oil slime inside the cam cover then
    give the engine a refresh with rings, bearings, mild port job and match port
    inlet & exhaust ports and maybe a thinner head gasket and that's it!
    Veteran slydar's Avatar
    Dimitri
    yeah. most hi po toyota motors are very well regarded by engine builders. i didnt bother with the one i just put together.
  1. VIC: Silvertop 20v TURBO Bottomend! Full Balance, ACL Forgies
    By Sprinter86 in forum Car Parts For Sale
    Last Post: 18th January 2011, 12:24 AM
  2. are bt 20v and silver top 20v cam covers the same??
    By slider4life in forum Technical - Questions
    Last Post: 1st April 2010, 06:08 PM
  3. can EASILY swap a st 20v for a bt 20v
    By dave2221 in forum Technical - Questions
    Last Post: 20th July 2009, 09:34 PM
  4. bt 20v
    By gunbz-r in forum Car Parts For Sale
    Last Post: 26th March 2008, 07:25 PM
