Results 1 to 2 of 2
Thread: 4agze Discussion
    Mick
    Penrith
    Default 4agze Discussion
    Just thought I'd get a topic going to talk about some different gze setups, and the running gear you guys are using. I have a gze from an ae92 Trueno (i think?) with crank and cam angle sensors, and a map sensor, not afm.
    I was thinking of putting it in my sprinter, but I can't be bothered with all the legal red tape, and i don't really drive hard on the street anyway, so I'm looking at putting it in my ke70 shell, and making a skid car for taking to the track.
    So what gearbox/diff combos are you using? I'm also looking for a decent ECU to use with it, it used to be run on a microtech, don't know much else apart from that. Also, torque specs would be handy. I searched and could only find 4age, unless they are the same...
    Mt Macedon
    Search the old forum, there was a whole thread just about the GZE, which should answer a lot. Actually... direct link to it, since search is hard to find on the old site now.
    And if by torque specs you mean bolt torques then yes, GE will be fine.
  1. Twincharging Discussion
    By Vezza in forum Technical - Questions
    Last Post: 29th March 2010, 07:43 PM
  2. 4AGZE discussion
    By Gilly in forum Technical - Questions
    Last Post: 30th September 2008, 01:16 AM
  3. 9AGE discussion
    By riojin in forum Technical - Questions
    Last Post: 9th May 2008, 11:18 PM
