Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: drift set up, what is yours and where to start.
    Question drift set up, what is yours and where to start.
    ok s I was going to do a sr conversion but have recently chosen to stick to my 4AGE for the time being. my 86 has had the suspension all done and sorted but i want to get into drifting just to give it a go I am planing on keeping the car on the road so it dose need to be RW to some degree. my build idea is this as of so far.
    t sereas diff and assorted parts to go with it. TRD 1.5 way LSD. oil cooler kit, more bracing, quad throttle bodies, rocker stoppers, TRD head gasket, replace water pump with NEW item, and at some point a cage.
    the car is modded to a 2 seater so i can run one, sound deadening is removed and n AC. is there anything i Have forgoten or that i should add to this list or am i about spot on. ?????? if this has been done to death i am sorry for asking agen. chears.
    necessary parts:
    2way preferably with T18 drums (atleast the handbrake will work then)
    P/S arms
    Good front tyres
    8/6 springs with good shocks
    Make sure the radiators up to the task
    oh and a bucket seat is a must
    Thats the basics.
    If your going to open up the engine you may aswell give the head a recon. Why the TRD head gasket? I run a modded head and block with a stock gasket, atleast it'l be the first thing to go if it over heats.
    Veteran blair's Avatar
    Blair
    Sheldon
    lol @ 2way as a neccessity...
    and P/S arms even.
    Veteran biggo's Avatar
    Nick
    Noosa
    lol at rocker stoppers
    never thought id see the day.
    Veteran johl's Avatar
    Johl
    do springs and shocks first, swaybars next, then camber tops, p/s arms, adj panhard. then if u want more add lca's, quick rack, 4 link.
    but realy you should have an ok setup with just springs, shocks and swaybars
    User fantapants's Avatar
    Pat
    done to death..... holy hell... ps wtf are rocker stoppers?
    06/07/2011
    Ryan
    qld
    brisbane
    Aust.
    start with the $100 combo (falcon springs and sierra shocks) and a locker
    you'll learn quickly what you need, you'll get confidence, but mainly if you stack it into a gutter its not going to bend expensive parts.
    stick that out as much as you can, then buy some good stuff.
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    TRD headgasket bumps up compresion yeah??
    Anyways, a basic set-up to have some fun isn't that hardcore to do....have a hit on a track standard and go from there it will give you an idea of what needs changing..
    EG. to much body roll (change springs and shocks to start with), single spins (lock it) and so on. over time you will learn about the car and wil understand everything.
    Listen to lads like johl...
    John 1:12
    性交を愛する
    A good left leg for kicking that clutch.
    And what everyone else has said.
    I have all the suspension done i got coil over's up front and unknowan at the back its solid as hell and i got the front and rear strut braces. the TRD head gasket quolity and i would rather pay for it not and bump up compresion than replace agen later. and rocker stoppers as added safety for the head. i was more asking for funny things that I would not have thought of as of yet. I didn't think of the PS arms i forot about that and i was thinking of using carona controll arms as a added.
  1. AE86 panda CA18DET drift set up super clean
    By phoenixx in forum Cars for Sale (Toyota Only)
    Last Post: 16th June 2012, 07:18 PM
