your off your head!!!
this should sell within a day
one of the best out there
regrettable sale to focus on other things more important
BODY
1984 ADM
deleted rear pockets tech arts/slydar style
hand flared front guards
kouki headlights, parkers
ADM zenki front bar + OEM Zenki lip
ADM rear bar
Kouki Whiteline tail light set
ENGINE + DRIVELINE
AE101 4AGZE
Kaizen S/C oulet pipe
180mm crank pulley
2" intercooler piping
unknown OEM intercooler
modified AE101 loom + ECU
T50
JDM bellend and hard lines
C's short shift
EXEDY pink bits H/D clutch
big single piece shaft
T18 series one housing
AJPS sway mounts
TRD 2 way
4.1 CW&P
FUEL
ADM tank + modified pick up + high pressure in tank EFI pump
under car surge tank
bosch 070 pump
8mm feed
adjustable reg
SUSPENSION
Front:
shortened strut, GAZ coilover kit, ST185 AGX, GAZ 8kg/mm springs + GAZ helpers
ADM brakes
Braided front brake lines (ADR approved)
p/s arms
XT130 LCA's, new bushes and ball joints
30mm RCA's
Quaife quick rack
T18 turnbuckle tierods
poly bushed sway links, mounts, castor rods
Spats strut brace
Rear:
GAZ 36 way adjustable coilovers
GAZ 6kg/m springs + GAZ helpers
JDM OEM sway bar (1mm larger dia blink.gif )
APEX rosejoint adjustable 4 link
APEX rosejoint panhard rod
APEX rosejoint sway bar links
RIMS
SSR Formula Mesh
front: 14x8.5 -20
Rear: 14x9 -15
185/60 FD1's
MA61 stockies, 14x7's good tyres all round
INTERIOR
Safety 21 6 point cage with b-pillar tags
rear harness brace
relocated battery to behind passenger seat
timeless blue ADM trim
body is not brilliant, the car came from the wreckers, in saying that rust is good and only in a few small managable spots. paint is also not brilliant but its good enough. has had a new screen fitted, no water leaks etc.
engine has oil leaks, really needs a reseal if you are serious. strong 180psi comp ration on all 4 cylinders. i haven't got it running well yet, had some vacuum leaks that i've now fixed and needs to be put back together timing and TPS adjusted and it should be sweet. i would do this but i no longer live where the car does and do not have the time or capabilities to do so.
front half of cage is supplied but not fitted as you need to md the dash to fit it
$7000 ONO rolling on MA61's, everything in the specs list included
add $1500 for SSR's which are availalbe seperate, have been offered to someone already awaiting their reply.
not interested in parting unless someone wants a roller with the ZE in it etc. really just needs a few solid hours work to be finished.
if you do some figures the value of the parts only well exceeds the asking price, clever cat with cash would buy it and part it, i would part it but it needs to be gone ASAP
I'm not psyched about this but shit happens and sometimes other things take priority.
if you are serious pm me, i'm not fielding calls yet i've got way too much happening, pm me and we can arrange a time to chat/view
heaps of pics in thread below
NEAR MISS
sounds like a very sad post
i hope everything is ok dude, hope your family is well, and your little one must be growing up fast
screw cars man, family is where its at!!
(how do i do a thumbs up in this new forum!)
cheers Dave, all my problems are self inflicted, iappreciate the gesture though
worth mentioning fornt and rear coilovers are brand new and yet to be driven on.
removed short shifter
first price drop to 6.5k
Its a steal at this price. Sorry to hear your not going to keep it.
Holy jesus. I thought I was imaging something when I saw 7k and then 6.5K. This is well worth buying, just to have some GDM specness. Hope everyting works out mate.
Bealy bought the meshies so they aren't availalbe seperate anymore
indeed 6.5k is a steal for pretty much 5 good years of parts collected.
includes spares too highlight being a t50 and t40 box, few starters and just random 4a crap, dumped roughly 300kg's of spares the other day
can piece together a cheaper package by removing cage, braces, lights etc, front bar etc will be sold at least as a roller
