Hey man, could be interested in the QR hub. Can you post a pic, Thanks Azz.
Hey guys
I've got a few things to sell. got photos of a few of them but i can get more if people are serious about buying.
1. Black leather steering wheel. red stitching, little yellow strip to tell you when your going straight haha. $70
2. Surge tank. screw in fittings. Worked really well in my car until I bought a tank that would fit under the car! $80
3. Quick release steering hub. Brand new, fitted once but i decided it didn't suit my seating position. $50 SOLD
4. set of brand new peugoet rotors to suit a hilux 4 spot brake setup commonly used in celicas/rollas. Same as used in that black celica with the big front mount oil cooler that keeps getting posted up! $100
5. Hilux 4 spot brake calipers to suit the above discs. $150
The only other thing needed to put the brake setup together is a set of xt130 struts.
6. smallport 4age ecu $75
7. fibreglass front lip to suit ke70. bought it from AJPS, primed it and painted it but I've decided I'd rather run a different front setup. $200
Located: Hobart Tas.
Thanks man, V prompt. I'm actually after a spacer for better wheel position. What sort of added depth would this give? Assuming it bolts straight up to a wheel boss.
Also, what brand is it, and would it come with fitting bolts/studs?
i bought it from racespec. It bolts to an aftermarket wheel boss same pattern as most aftermarket steering wheels.
It comes with bolts, allen key, wires for the horn, and japanese instructions.
Its about 63mm in length
reallly really tempted to that fibreglass lip....hhhmmm.....might trial fit it and see how it looks
MY AE86 BUILD
swap it for you caliper adaptors
Oh by the way its the foha lip to suit slanty fronts. It might fit a flat front im not really sure though
gay, was hoping for a madhouse type lip...
MY AE86 BUILD
yeah. but since i think slanties look WAY better than the old 1950's flat front I went ahead and bought a lip to suit that
edit: A LOT of interest in the quick release steering hub!! Just noticed that theres another one just like mine only not as sexy for $110!!!
Funny thing is i had mine advertised for $60 a few months back and no interest
