Results 1 to 9 of 9
Thread: Rust repair jobs
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Default Rust repair jobs
    so...........
    im sure everyone has attempted this
    has anyone done a real simple and effective method of rust repair?...
    sand back, spray rust converter bullsh!t, paint....well something like that..
    im not talking about converting a rust bucket into a car, just some simple rust repair method and how effective it is, ive had my attempts and they seem to work, but the ones that needs more attention, we'll i need more info on how to fix em
    dose
    Senior Member 45aken's Avatar
    Marko
    If your going to do it right this time with money pay a shop to weld in new steel (if you cant weld)
    it's the only way man,
    you can rust convert and bog it all you want but the filthy rust will still come back.
    性交を愛する
    IMO Chop the shit out weld steel in and bog it up.
    If you don't know how to do it, learn.
    Veteran drift kid's Avatar
    Glossodia
    if it's not a big patch, just some little holes, cut it out and get some "knead it" from bunnings, it's an epoxy metal filler thingy, mash it up, plug hole with it and file/sand, if needed putty then sand, paint all done, but if the hole is too big u should make peice to go in the hole nicely, weld it in, bog up sand then paint, all good, not hard.
    john
    nsw
    liverpool
    Richard
    Liverpool
    thnx drift kid and redsprinter
    dose
    Senior Member mals86's Avatar
    MAL
    Cairns
    Yeah the more steel you can use the better, just play with the shape etc till you get it nice and snug. another way is to slightly tap in the edges around the hole just enough so the new piece sits in flush. Then weld and grind to make it look good, but also try to use some rust converter/primer to keep it from going rusty again.
    Dave
    The Ghetto
    how about some fairly gd surface rust? what would be the best way e.g. on struts
    Marko
    The best way would be to sand blast it off and then paint it.
    more practical way would be wire brush, sand, etch prime, prime then paint.
    It took me about 6 weeks to cut the rust out and weld new steel into my car, do it right the first time and it'll be good for another 20 years.
  1. Sill Sections for rust repair
    By Futal in forum Cars or Parts Wanted
    Last Post: 1st December 2012, 10:00 AM
  2. Where to get Rust repair and full respray in Sydney
    By Mikeylimiter in forum General Topics (No Technical Questions)
    Last Post: 20th July 2012, 08:47 PM
  3. Rust Repair Thread
    By KE70GT in forum Technical - Questions
    Last Post: 7th April 2011, 10:17 PM
  4. rust repair places in SE suburbs
    By banzai_pots in forum Melbourne & Vic Events and Discussion
    Last Post: 3rd April 2009, 09:41 PM
  5. RUST REPAIR...YO
    By intense in forum Technical - Articles
    Last Post: 10th October 2006, 09:34 PM
