Results 1 to 4 of 4
Thread: How to remove window plastics
    Jon
    Durack
    Default How to remove window plastics
    hey guys i need to remove my window plastics but dont want to risk breaking them is there a way to do it with ease???
    Senior Member 45aken's Avatar
    Marko
    rear quarters? windscreen? door?
    Jon
    Durack
    all of the above
  • #4
    Marko
    front windscreen has a screw at the bottom and you slide out the rubber revealing 3 screws, should come off with no force with the screws gone. the top strip might be glued on, use a scraper/stanely. if if is clipped on you can pop it off the clips with a small screwdriver, there is 3 i think spaced along it. or if you get the sides off first you may be able to slide it off.
    doors have maybe 3 screws on the bottom one, the rest just pull off.
    rear quarters are all clipped on, start at a corner and clip them off with a small screwdriver. if you do one side the other side just falls out.
    back glass is a bitch. i started on the inside and with multiple flat heads started peeling the rubber until i could push the window out a bit and tuck the rubber into the outside, then moved along. go super slowly with this or you'll break shit.
    hope that helped
  • Similar Threads
    1. Replies: 8
      Last Post: 15th January 2012, 05:27 PM
    2. WTB - rear seat hinges and exterior window plastics
      By checkers in forum Cars or Parts Wanted
      Last Post: 19th June 2010, 03:41 PM
    3. FS: ae86 rear window wiper motor and window wiper
      By angelo in forum Car Parts For Sale
      Last Post: 12th April 2009, 04:58 PM
    4. Replies: 0
      Last Post: 2nd February 2009, 09:37 PM
    5. WTB: notch back rear quater window window mouldings
      By shinobi in forum Cars or Parts Wanted
      Last Post: 5th January 2009, 12:09 PM
