Results 11 to 20 of 29
Thread: Mr A's painting D.I.Y.
  1. #11
    Senior Member JUG-HEAD's Avatar
    Ash
    Para Hills
    this will definetly be coming in handy soon, good write up mate
    4AGTE 86 TRACK PIG
    92' Toyota Lolux 22RE daily weapon!
    AJPS FTMFW!!!!111
  2. #12
    Dave
    far out that came out nice. well done.
    i missed out most of those steps when i did mine.....i can see the advantages of taking the doors off, working with them on the car is a pain....thus there are still dents in mine
    what kind of paint are you using? since you arent rubbing it back i assume 2-pak or enamel?
    - Blaise Pascal
  3. #13
    User fantapants's Avatar
    Pat
    Well played!
    06/07/2011
  4. #14
    Senior Member Mr Awsome's Avatar
    Dave
    Plympton
    enamel in sides coz its easy and will go over almost anything and 2 pack out sides coz i wouldn't use anything else on the out side.
    still needs a minor polishing. came out pretty well considering the compressor and the whole spraying out doors.
    i for got to add with a compressor like that, be prepared to stop after like 4 strokes and wait for it to refill the tank with pressure or prepared to go really slow with your gun control.
  5. #15
    Dave
    didnt die to much from the 2-pak fumes?
    i was gonna go 2-pak, purely for the fact that it was shine off the gun (or close to), but yer was a bit wary of the fumes. but ended up going acrylic (and the fumes were bad enough!), and was to lazy to buff back the clear coat for about 1yr....
    - Blaise Pascal
  6. #16
    Senior Member sotiros86's Avatar
    Andrew
    Wollongong
    I was under the impression that 2 pack doesnt properly harden unless baked and that it is extremely dangerous to spray outside of a booth.
    Im just curious as i will be re-spraying my 64 Pontiac Parisienne in the next couple of months, and was planning on using acrylic as i had been told that you cant get a decent finish with 2 pack unless it is sprayed in a booth (and also cause im a tight ass lol). I have also been told that 2 pack is considerably harder to paint than acrylic, did you find this to be true?
  7. #17
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    did u use an oven because it doesnt look like you did for the 2pack?
    care to elaborate please.
  8. #18
    Ok
    Seamus
    Milton
    ^ He didn't. 2-pack dries fine without an oven, it just takes a while for the paint to *completely* harden.
  9. #19
    Dave
    Plympton
    no booth it was 43o when i painted it . a booth & good air pressure would of been better. i painted it in my carport on gravel.
  10. #20
    Filip
    Jozzaville
    ahh i see.
    thanks for the explanation
  1. Project MR Busa
    By DX20VT in forum Other Toyotas
    Last Post: 30th December 2011, 08:47 AM
  2. MR A's...Track car!
    By Mr Awsome in forum AE86 Owners Forums
    Last Post: 9th December 2011, 03:44 PM
  3. Mr Fujiwaras Ae86
    By Mr Fujiwara in forum AE86 Owners Forums
    Last Post: 13th August 2009, 07:53 PM
  4. arigatou Mr Roboto
    By eastcoastdrifter in forum Toyotas in the Media
    Last Post: 29th October 2006, 09:23 PM
  5. MR - 20V --- (Hayden) --- ???
    By wide s13 in forum General Topics (No Technical Questions)
    Last Post: 26th May 2005, 02:31 PM
