Hey guys. I have an SR20DET blacktop out of a late model 180sx taking up space that I need to get rid of.
The engine is perfect, any inspections are welcome. It’s been looked after very well and it shows as there is absolutely no gunk under the rocker cover and the sump pick up and rest of the motor is absolutely clean. Come compression test it, leak down test it etc.
The motor comes with these standard accessories:
- Ecu
- Loom
- Alternator
- Starter Motor (manual)
- AFM
- Non Hicas Power Steering Pump
- Air conditioner pump
- Fuel Injectors
- Coil Packs with coil pack loom
- Clutch Fan
- CAS (Has a cracked cover but it still works)
- T25g (Has shaft play)
- S13 SR20DET Standard radiator
- SR20 Fan Shroud.
- Flywheel
- 3 Puck Clutch
With the motor I will include these extra goodies:
- New Midnightmods Braided turbo lines
- 3" Stainless Bell mouth Dump Pipe
I’m chasing $2500 for the Package, Keep in mind this is cheaper than wreckers I have called. Most wreckers wont allow you to comp test the engine.
Can Deliver it to metro suburbs around Melbourne for an extra $50.
The only things that I can think of that are missing is the Ignitor. Cheap Item but If you can wait I will buy them from a wrecker and include them in the sale.
Location: Ashburton, Melbourne SE. Not too far from Chadstone shoppping centre.
Contact: Jarryd 0433 150 720 Or PM me.
Last edited by All Drift Modifications; 4th February 2010 at 05:47 PM. Reason: Photos added
